HIGHLIGHTS (added by HondaFan81):
The Bisimoto heatshielding gasket reduces intake manifold temps by over 50 degrees. This allows a denser intake charge mixture and hence more power. It is an excellent upgrade from OE. Make sure to add some silicone sealant around the coolant passage for added insurance against leakage.
Not all of the commercially available gaskets are the same. Many companies use simple and cheap plastic, which melt when exposed to engine heat. You do get what you pay for. We have seen a 7hp gain on the stock F22, and another great advantage of it being reusable. Boosted applications gain even more from this mod due to the heat that the turbocharged engines can generate.
F22ax Dyno Chart:
Applications:
F22ax, H22ax and others, check out Bisimoto website.
Price:
$48 each, and we will always manufacture them.
Members Add Pertinent Shipping Cost:
- Free shipping within continental U.S.
- $9.33 for shipping to Alaska, Hawaii.
Member Payment Procedure:
- Place order by phone 888-922-6686 (888-9-BC-MOTO)
OR
- Place order via Paypal directly (lab@bisimoto.com) with full appropriate shipped price (based on info above). Mention "CB7tuner member & heatshield IM gasket" in subject.
F22ax Dyno Chart:
Applications:
Price:
OR
