what will i need to get started?
    i believe moates has the chips and burners, also check out uberdata's website for info, i usually find myself reading up on stuff in there cause i too am in the same boat as you and want to learn, i believe the chip after is burned will come with a basemap, and you should get it tuned, if not its going to be the same as the the stock ecu
    Members Ride
      ask d112crzy or accordr33 or mrx they have a lot of experience when it comes to this kind of stuff,
      you will also need a program such as uberdata, crome, there are a couple of them, but like i said, i too am a noob on this
      Members Ride
        there was a thread devoted to what exactly you need try looking at the tuning section.
        what you will need is laptop, tuning software, datalogging software, chipped p06 and chips, datalogging cord, wideband o2 sensor, hmm what else oh yeah lots of patience.
          things you NEED
          1. civic/integra OBD1 ECU (p05,p06,p75,).
          2. Chip kit. either http://ww.moates.net or http://www.xenocron.com/
          3. Crome www.tunewithcrome.com
          4. Chip burner. www.moates.net or search ebay for willem burners (a little less user friendly)
          5. Base map. completely depends on your setup, i assume MRX would be the best source for this if he is willing to distribute them.
          6. Wideband O2 sensor. i reccomend either the innovate LC-1 or the Zeitronix.
          Optional, but recommended:
          Laptop
          some kind of datalogging program. listed here in order from best to worse in MY opinion
          1. Crome Pro
          2. FreeLog
          3. ECUcontrol
          Moates.net Ostritch, for real time programming
          Moates.net HondaLog datalogging cable, or Modified Nokia Datalogging cable
          Dyno Session
          EGT gauge.
          Useful links:
          http://www.pgmfi.org/twiki/bin/view/Library/WhatYouNeed
          http://www.pgmfi.org/twiki/bin/view/...nToECUChipping
          http://www.pgmfi.org/twiki/bin/view/...ngWithPictures
          http://www.pgmfi.org/twiki/bin/view/.../BasicConcepts
          http://www.pgmfi.org/twiki/bin/view/...erstandingMaps
          Good luck. now we shouldn't need to see another thread like this from anyone..even though we will
            Originally posted by Accord R33
            things you NEED
            1. Crome Pro
            2. FreeLog
            3. ECUcontrol
            so im guessing that uberdata is either bad, not as good anymore, or ceases to exist, caust i'm still learning from that program
            "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
            I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
              It still works, but development has stopped on it. I find Crome to be far superior these days.
