Our 91 EX auto sedan - Mulberry Red Pearl
    This car has 149,XXX miles on it currently and was purchased from Dallas, Texas from "mrhonda - Corey" from this forum. This car was bought by my dad for my youngest sister and will be her car. It has no body rust and is in great shape. The following work was done by mrhonda/Corey.
    Corey's work:
    - new radiator, radiator hoses & thermostat, coolant flush
    - full timing belt package (water pump, belt, seal retainer, etc.)
    - all front engine seals replaced
    - new fuel filter, air filter, spark plugs, wires, plugs, cap & rotor kit
    - A/C pressure switch replaced & A/C system recharged
    - 4 new Kumho tires
    - wheel alignment
    - All needed CV boots replaced
    - new front end-links
    - full valve cover gasket kit (including lower tube O-rings)
    - new battery
    - motor oil change
    - ATF change
    - new OEM wiper blade assemblies
    - 35% tint all-around
    My work:
    - Mobil1 5W-30 oil change
    - K&N air filter
    - front passenger upper control arm replaced (only joint boot that is ripped)
    - sprayed silicone spray on all rubber boots
    - full wash & wax job, cleaned up wheels/tires & outside glass
    - fixed rear-passenger power window, works now
    - fixed rear-driver power door lock, works now
    - replaced rear trunk carpet, new OEM gray
    - fixed leaky tire, had a bad plug
    - F22a6 good used TCU
    - new stock exhaust/muffler
    Photos after wash & wax job:
    ** Night pics for now, daytime later **
    clean ride
    -1993 Accord EX SOLD
    -2012 GMC Canyon V8 4x4
      good deal dude
        nice its real clean
          chaulk one up for Cisco good shit
          Formerly 91AccordExR33
          11.68 @ 127mph
          417whp/375wtq
          Sold: 8/2016
            Nice car man. Reading that list gives me an idea of what I need to do to mine. I bought it a year ago and haven't done any serious maintenance.
            What seals exactly were included in this:
            And for the timing belt package, it was the timing belt, balance shaft belt, water pump, retainer, and what else?
            What's the AC pressure switch?
              looks good
                - front camshaft seal
                - front crankshaft seal
                - front balancer shaft seal & seal retainer
                - timing belt package is (timing belt, balancer belt, water pump and balancer shaft seal retainer which was included above)
                Not positive on the A/C pressure switch, would have to look that up in the manual. Corey did that work, he'd know (mrhonda).
                  nice color
                  My Members Ride Thread
                    Nice pick up. Pretty color. I see that color rarely down here and it is definately not in that condition if it ever is spotted.
                    "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
                    FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
                    http://www.cb7tuner.com/vbb/showthre...10#post2119010
                      Updated the progress (first post) on this car. Everything is fixed and works great!! My little sister is so happy to be driving it. Later it will probably get an aftermarket CD headunit and possibly aftermarket speakers as well. I'd like to install a Progress rear sway bar and Neuspeed front upper brace as well on this car. I also plan to install the Tokico HP springs on Tokico HP shocks for my sister, of course all this is if she gets the money for it. I think with all that, she'll be content driving it.
                        Hell yeah! Looks great Cisco, matter of fact...looking at these pics is making me miss it. I guess you could say I have a little sentimental attachment to this car. For those who don't know, this is the one that I rescued last winter. It was abandoned by the previous owner and ended up in the local boneyard, all because it had a broken timing belt. I bought it, fixed it up (had to replace 7 valves!), drove it for a few months, and ended up selling it to Cisco. I'm just glad to see that it went to a good home.
                        00 Jeep Grand Cherokee 4.7 V8 4X4
                        92 Honda Accord LX
                        95 Honda Civic CX
