Aye I'm going to be droping my car sometime this month and I wanted to know that does it matter what chamber kit I get. I'm going 3in all around. So do some chambers correct certian degrees or are they all the same? If so which one should I get for a 3in to 3.5in drop?
is there certain chamber kits for certain drops
No offense, by "chamber kit", I guess U meant "camber kit". Yes, there is differences of correction range for different drop. The manufacturer usually claims or states what range of drop is the camber designed for.
Check with the manufacturer or check the description of the item.
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
3", I would do the upper-ball joint (adjustable type) on the front, otherwise you will have the upper-a arm hammering the inner fender. Also, either use the washer trick on the rear, or purchase the adjustable pieces..... You can probably adjust almost, if not all of the camber out. Clearance might be the only issue if you are running aftermarket wheels/tires. Got these pics from a great manufacturer, http://www.ingallseng.com/
Adjustable A-arm bushings
Ball joints
Rear either
or washers, not much correction here though....but cheaper
Is the ball joint kit better then the other type of kit thats out there? Mines from progress technology and its the anchor bolt design i believe is what its called and im dropped about 2 1/2 inches and my front arms bang like hell when i hit a bump in the road. Oddly enough they dont knock when i hit a dip, its just usually a bump or change in road type of bump, so is that my upper arm or is something else i should be looking at?1991 Black Accord Coupe
Sprint Lowering Springs
Neuspeed/Koni Sport Shocks
Suspension Techniques Front and Rear Sway Bar
17" Motegi DP6 with Bridgestone Potenzas
TSX HID Retrofit with 4300K Bulbs
http://www.cardomain.com/id/sthrnba711
