** This thread was originally posted by Innovation on Honda-Tech so full credit goes to him. **
Blocks
BLOCK TYPE
H22A = closed deck (With the exception of later-model "OBD2" Japanese engines.)
H22A1 = closed deck
H22A4 = open deck
H23A = open deck (With the exception of the H23A found in the Ascot Innova that is effectively the H23A1 with the "1" dropped.)
H23A1 = closed deck
F20A = open deck
F20B = open deck
F22A = open deck
F22B = open deck
F22B1 = open deck
F22B2 = open deck
F22B6 = open deck
F23A = open deck
F20C = open deck
F22C = open deck
CYLINDER MATERIAL
H22A = FRM
H22A1 = FRM
H22A4 = FRM
H23A = FRM
H23A1 = FRM
F20A = iron
F20B = iron
F22A = iron
F22B = iron
F22B1 = iron
F22B2 = iron
F23A = iron
F20C = FRM
F22C = FRM
DECK HEIGHT
H22A = 219.5mm/8.643
H22A1 = 219.5mm/8.643
H22A4 = 219.5mm/8.643
H23A = 219.5mm/8.643
H23A1 = 219.5mm/8.643
F20A = 219.5mm/8.643
F20B = 219.5mm/8.643
F22A = 219.5mm/8.643
F22B = 219.5mm/8.643
F22B1 = 219.5mm/8.643
F22B2 = 219.5mm/8.643
F23A = 219.5mm/8.643
F20C = 223.9mm/8.815
F22C = 223.9mm/8.815
BORE
H22A block = 87mm/3.425
H22A1 block = 87mm/3.425
H22A4 Block = 87mm/3.425
H23A block = 87mm/3.425
H23A1 block = 87mm/3.425
F20A block = 85mm/3.346
F20B block = 85mm/3.346
F22A block = 85mm/3.346
F22B block = 85mm/3.346
F22B1 block = 85mm/3.346
F22B2 block = 85mm/3.346
F23A block = 86mm/3.385
F20C block = 87mm/3.425
F22C block = 87mm/3.425
Rods
LENGTH
H22A = 143.0mm/5.633
H22A1 = 143.0mm/5.633
H22A4 = 143.0mm/5.633
H23A = 141.0mm/5.551
H23A1 = 141.5mm/5.572 (With the exception of the H23A found in the Ascot Innova that is effectively the H23A1 with the "1" dropped.)
F20A = 145.0mm/5.709
F20B = 145.0mm/5.709
F22A = 141.5mm/5.572
F22B = 141.5mm/5.572
F22B1 = 141.5mm/5.572
F22B2 = 141.5mm/5.572
F23A = 141.0mm/5.551
F20C = 153.0mm/6.023
F22C = 149.65mm/5.892
WIDTH
H22A = 23.75mm/.935
H22A1 = 23.75mm/.935
H22A4 = 23.75mm/.935
H23A = 23.75mm/.935
H23A1 = 23.75mm/.935
F20A = 23.75mm/.935
F20B = 23.75mm/.935
F22A = 23.75mm/.935
F22B = 23.75mm/.935
F22B1 = 23.75mm/.935
F22B2 = 23.75mm/.935
F23A = 19.81mm/.780
F20C = 23.75mm/.935
F22C = 23.75mm/.935
MAIN BORE
H22A = 51.00mm/2.008
H22A1 = 51.00mm/2.008
H22A4 = 51.00mm/2.008
H23A = 51.00mm/2.008
H23A1 = 51.00mm/2.008
F20A = 48.00mm/1.890
F20B = 48.00mm/1.890
F22A = 51.00mm/2.008
F22B = 51.00mm/2.008
F22B1 = 51.00mm/2.008
F22B2 = 51.00mm/2.008
F23A = 48.00mm/1.890
F20C = 51.00mm/2.008
F22C = 51.00mm/2.008
PIN BORE
H22A = 21.97-21.98mm/.8649-.8654
H22A1 = 21.97-21.98mm/.8649-.8654
H22A4 = 21.97-21.98mm/.8649-.8654
H23A = 21.97-21.98mm/.8649-.8654
H23A1 = 21.97-21.98mm/.8649-.8654
F20A = 21.97-21.98mm/.8649-.8654
F20B = 21.97-21.98mm/.8649-.8654
F22A = 21.97-21.98mm/.8649-.8654
F22B = 21.97-21.98mm/.8649-.8654
F22B1 = 21.97-21.98mm/.8649-.8654
F22B2 = 21.97-21.98mm/.8649-.8654
F23A = 21.97-21.98mm/.8649-.8654
F20C = 22.97-22.98/.9043-.9047
F22C = 22.97-22.98/.9043-.9047
Pistons
BORE
H22A = 87mm/3.425
H22A1 = 87mm/3.425
H22A4 = 87mm/3.425
H23A = 87mm/3.425
H23A1 = 87mm/3.425
F20A = 85mm/3.346
F20B = 85mm/3.346
F22A = 85mm/3.346
F22B = 85mm/3.346
F22B1 = 85mm/3.346
F22B2 = 85mm/3.346
F23A = 86mm/3.385
F20C = 87mm/3.425
F22C = 87mm/3.425
COMPRESSION HEIGHT
H22A = 31.0mm/1.221
H22A1 = 31.0mm/1.221
H22A4 = 31.0mm/1.221
H23A = 30.5mm/1.203
H23A1 = 30.5mm/1.203
F20A = ???
F20B = 31.0mm/1.221
F22A = 30.5mm/1.203
F22B = 30.5mm/1.203
F22B1 = 30.5mm/1.203
F22B2 = 30.5mm/1.203
F23A = 30.0mm/1.181
F20C = 30.0mm/1.181
F22C = 30.0mm/1.181
PISTON VOLUME
H22A = -1.9 cc
H22A Type S = +4.2 cc
H22A1 = -1.8 cc
H22A4 = -1.8 cc
H23A = +4.3 cc
H23A1 = -9.9 cc
F20A = -4.7 cc
F20B = +8.0 cc
F22A = -14.5 cc
F22B = -11.2 cc
F22B1 = -14.5 cc
F22B2 = -14.5 cc
F23A = -18.0 cc
F20C = +1.05 cc(unconfirmed-just a calculated figure based on a 30mm compression height)
WRIST PIN DIAMETER
H22A = 22.0mm/.866
H22A1 = 22.0mm/.866
H22A4 = 22.0mm/.866
H23A = 22.0mm/.866
H23A1 = 22.0mm/.866
F20A = 22.0mm/.866
F20B = 22.0mm/.866
F22A = 22.0mm/.866
F22B = 22.0mm/.866
F22B1 = 22.0mm/.866
F22B2 = 22.0mm/.866
F23A = 22.0mm/.866
F20C = 23.0mm/.905
F22C = 23.0mm/.905
Crankshafts
STROKE
H22A = 90.7mm/3.570
H22A1 = 90.7mm/3.570
H22A4 = 90.7mm/3.570
H23A = 95mm/3.740
H23A1 = 95mm/3.740
F20A = 88mm/3.464
F20B = 88mm/3.464
F22A = 95mm/3.740
F22B = 95mm/3.740
F22B1 = 95mm/3.740
F22B2 = 95mm/3.740
F23A = 97mm/3.818
MAIN JOURNAL DIAMETER
H22A = 50mm
H22A1 = 50mm
H22A4 = 55mm
H22A4 = 50mm (1997 Only)
H23A = 55mm
H23A1 = 50mm
F20A = 50mm
F20B = 55mm
F22A = 50mm
F22B = 50mm
F22B1 = 50mm
F22B2 = 50mm
F23A = 55mm
ROD JOURNAL DIAMETER
H22A = 47.95mm/1.888
H22A1 = 47.95mm/1.888
H22A4 = 47.95mm/1.888
H23A = 47.95mm/1.888
H23A1 = 47.95mm/1.888
F20A = 47.95mm/1.888
F20B = 44.98mm/1.771
F22A = 47.95mm/1.888
F22B = 47.95mm/1.888
F22B1 = 47.95mm/1.888
F22B2 = 47.95mm/1.888
F23A = 44.98mm/1.771
Cylinder Heads
HEAD VOLUME
H22A = 53.8cc
H22A1 = 53.8cc
H22A4 = 53.8cc
H23A = 53.8cc
H23A1 = 50.0cc
F20A = 50.0cc
F20B = 53.8cc
F22A = 50.5cc
F22B = 50.5cc
F22B1 = 50.6cc
F22B2 = 50.6cc
F23A = 50.6cc
INTAKE VALVE DIAMETER
H22A = 35mm/1.38
H22A1 = 35mm/1.38
H22A4 = 35mm/1.38
H23A = 35mm/1.38
H23A1 = 34mm/1.34
F20A = 34mm/1.34
F20B = 34mm/1.34
F22A = 34mm/1.34
F22B = 34mm/1.34
F22B1 = 34mm/1.34
F22B2 = 34mm/1.34
F23A = 34mm/1.34
EXHAUST VALVE DIAMETER
H22A = 30mm/1.18
H22A1 = 30mm/1.18
H22A4 = 30mm/1.18
H23A = 30mm/1.18
H23A1 = 29mm/1.14
F20A = 29mm/1.14
F20B = 29mm/1.14
F22A = 29mm/1.14
F22B = 29mm/1.14
F22B1 = 29mm/1.14
F22B2 = 29mm/1.14
F23A = 29mm/1.14
Head Gaskets
BORE
H22A = 88mm/3.46
H22A1 = 88mm/3.46
H22A4 = 88mm/3.46
H23A = 88mm/3.46
H23A1 = 88mm/3.46
F20A = 85.5mm/3.37
F20B = 85.5mm/3.37
F22A = 85.5mm/3.37
F22B = 85.5mm/3.37
F22B1 = 85.5mm/3.37
F22B2 = 85.5mm/3.37
F23A = 86.5mm/3.41
THICKNESS
H22A = 0.66mm/.026
H22A1 = 0.66mm/.026
H22A4 = 0.66mm/.026
H23A = 0.66mm/.026
H23A1 = 0.66mm/.026
F20A = 0.66mm/.026
F20B = 0.66mm/.026
F22A = 0.66mm/.026
F22B = 0.66mm/.026
F22B1 = 0.66mm/.026
F22B2 = 0.66mm/.026
F23A = 0.66mm/.026
Note:
Gasket thickness measured after crush
Bearings
MAIN BEARING THICKNESS
Blue: 2.013 - 2.010mm / 0.0793 - 0.0791
Black: 2.010 - 2.007mm / 0.0791 - 0.0790
Brown: 2.007 - 2.004mm / 0.0790 - 0.0789
Green: 2.004 - 2.001mm / 0.0789 - 0.0788
Yellow: 2.001 - 1.998mm / 0.0788 - 0.0787
Pink: 1.998 - 1.995mm / 0.0787 - 0.0785
Red: 1.995 - 1.992mm / 0.0785 - 0.0783
ROD BEARING THICKNESS
Blue: 1.510 - 1.507mm / 0.0594 - 0.0593
Black: 1.507 - 1.504mm / 0.0593 - 0.0592
Brown: 1.504 - 1.501mm / 0.0592 - 0.0591
Green: 1.501 - 1.498mm / 0.0591 - 0.0590
Yellow: 1.498 - 1.495mm / 0.0590 - 0.0589
Pink: 1.495 - 1.492mm / 0.0589 - 0.0587
Red: 1.492 - 1.489mm / 0.0587 - 0.0586
MAIN BEARING WIDTH
H22A = 19.9mm/.784
H22A1 = 19.9mm/.784
H22A4 = 19.9mm/.784
H23A = 19.9mm/.784
H23A1 = 19.9mm/.784
F20B = 19.9mm/.784
F22A = 19.9mm/.784
F22B = 19.9mm/.784
F22B1= 19.9mm/.784
F22B2= 19.9mm/.784
F23A = 19.9mm/.784
ROD BEARING WIDTH
H22A = 19.35mm/.762
H22A1 = 19.35mm/.762
H22A = 19.35mm/.762
H23A = 19.35mm/.762
H23A1 = 19.35mm/.762
F20A = 19.35mm/.762
F20B = 19.35mm/.762
F22A = 19.35mm/.762
F22B = 19.35mm/.762
F22B1 = 19.35mm/.762
F22B2 = 19.35mm/.762
F23A = 15.47mm/.609
** Full credit goes to Innovation, PirateMcFred, prelittledude, Jdogg, ZigenBallz and HondaFan81 for this information. **
Blocks
BLOCK TYPE
H22A1 = closed deck
H22A4 = open deck
H23A1 = closed deck
F20A = open deck
F20B = open deck
F22A = open deck
F22B = open deck
F22B1 = open deck
F22B2 = open deck
F22B6 = open deck
F23A = open deck
F20C = open deck
F22C = open deck
CYLINDER MATERIAL
H22A = FRM
H22A1 = FRM
H22A4 = FRM
H23A = FRM
H23A1 = FRM
F20A = iron
F20B = iron
F22A = iron
F22B = iron
F22B1 = iron
F22B2 = iron
F23A = iron
F20C = FRM
F22C = FRM
DECK HEIGHT
BORE
Rods
LENGTH
WIDTH
H22A = 23.75mm/.935
H23A = 23.75mm/.935
F20A = 23.75mm/.935
F20B = 23.75mm/.935
F22A = 23.75mm/.935
F22B = 23.75mm/.935
F23A = 19.81mm/.780
F20C = 23.75mm/.935
F22C = 23.75mm/.935
MAIN BORE
PIN BORE
Pistons
BORE
H22A = 87mm/3.425
H22A1 = 87mm/3.425
H22A4 = 87mm/3.425
H23A = 87mm/3.425
H23A1 = 87mm/3.425
F20A = 85mm/3.346
F20B = 85mm/3.346
F22A = 85mm/3.346
F22B = 85mm/3.346
F22B1 = 85mm/3.346
F22B2 = 85mm/3.346
F23A = 86mm/3.385
F20C = 87mm/3.425
F22C = 87mm/3.425
COMPRESSION HEIGHT
H22A = 31.0mm/1.221
H23A = 30.5mm/1.203
F20A = ???
F20B = 31.0mm/1.221
F22A = 30.5mm/1.203
F22B = 30.5mm/1.203
F23A = 30.0mm/1.181
F20C = 30.0mm/1.181
F22C = 30.0mm/1.181
PISTON VOLUME
H22A = -1.9 cc
H22A1 = -1.8 cc
H22A4 = -1.8 cc
H23A = +4.3 cc
H23A1 = -9.9 cc
F20A = -4.7 cc
F20B = +8.0 cc
F22A = -14.5 cc
F22B = -11.2 cc
F22B1 = -14.5 cc
F22B2 = -14.5 cc
F23A = -18.0 cc
WRIST PIN DIAMETER
H22A = 22.0mm/.866
H22A1 = 22.0mm/.866
H22A4 = 22.0mm/.866
H23A = 22.0mm/.866
H23A1 = 22.0mm/.866
F20A = 22.0mm/.866
F20B = 22.0mm/.866
F22A = 22.0mm/.866
F22B = 22.0mm/.866
F22B1 = 22.0mm/.866
F22B2 = 22.0mm/.866
F23A = 22.0mm/.866
F20C = 23.0mm/.905
F22C = 23.0mm/.905
Crankshafts
STROKE
H22A = 90.7mm/3.570
H23A = 95mm/3.740
H23A1 = 95mm/3.740
F20A = 88mm/3.464
F20B = 88mm/3.464
F22A = 95mm/3.740
F22B = 95mm/3.740
F22B1 = 95mm/3.740
F22B2 = 95mm/3.740
F23A = 97mm/3.818
H22A = 50mm
H22A1 = 50mm
H22A4 = 55mm
H23A = 55mm
H23A1 = 50mm
F20A = 50mm
F20B = 55mm
F22A = 50mm
F22B = 50mm
F22B1 = 50mm
F22B2 = 50mm
F23A = 55mm
Cylinder Heads
HEAD VOLUME
H22A = 53.8cc
H22A1 = 53.8cc
H22A4 = 53.8cc
H23A = 53.8cc
H23A1 = 50.0cc
F20A = 50.0cc
F20B = 53.8cc
F22A = 50.5cc
F22B = 50.5cc
F22B1 = 50.6cc
F22B2 = 50.6cc
F23A = 50.6cc
H22A = 35mm/1.38
H22A1 = 35mm/1.38
H22A4 = 35mm/1.38
H23A = 35mm/1.38
H23A1 = 34mm/1.34
F20A = 34mm/1.34
F20B = 34mm/1.34
F22A = 34mm/1.34
F22B = 34mm/1.34
F22B1 = 34mm/1.34
F22B2 = 34mm/1.34
F23A = 34mm/1.34
H22A = 30mm/1.18
H22A1 = 30mm/1.18
H22A4 = 30mm/1.18
H23A = 30mm/1.18
H23A1 = 29mm/1.14
F20A = 29mm/1.14
F20B = 29mm/1.14
F22A = 29mm/1.14
F22B = 29mm/1.14
F22B1 = 29mm/1.14
F22B2 = 29mm/1.14
F23A = 29mm/1.14
Head Gaskets
BORE
H22A = 88mm/3.46
H22A1 = 88mm/3.46
H22A4 = 88mm/3.46
H23A = 88mm/3.46
H23A1 = 88mm/3.46
F20A = 85.5mm/3.37
F20B = 85.5mm/3.37
F22A = 85.5mm/3.37
F22B = 85.5mm/3.37
F22B1 = 85.5mm/3.37
F22B2 = 85.5mm/3.37
F23A = 86.5mm/3.41
THICKNESS
H22A = 0.66mm/.026
H22A1 = 0.66mm/.026
H22A4 = 0.66mm/.026
H23A = 0.66mm/.026
H23A1 = 0.66mm/.026
F20A = 0.66mm/.026
F20B = 0.66mm/.026
F22A = 0.66mm/.026
F22B = 0.66mm/.026
F22B1 = 0.66mm/.026
F22B2 = 0.66mm/.026
F23A = 0.66mm/.026
Note:
Bearings
MAIN BEARING WIDTH
H22A = 19.9mm/.784
H22A1 = 19.9mm/.784
H22A4 = 19.9mm/.784
H23A = 19.9mm/.784
H23A1 = 19.9mm/.784
F20B = 19.9mm/.784
F22A = 19.9mm/.784
F22B = 19.9mm/.784
F22B1= 19.9mm/.784
F22B2= 19.9mm/.784
F23A = 19.9mm/.784
ROD BEARING WIDTH
H22A = 19.35mm/.762
H22A = 19.35mm/.762
H23A = 19.35mm/.762
F20A = 19.35mm/.762
F20B = 19.35mm/.762
F22A = 19.35mm/.762
F22B = 19.35mm/.762
F23A = 15.47mm/.609
