hey.. yesterday.. i finished my swap.. when i go to start the car.. when i turn the key twice.. the gauge lights n all that stuff doesnt turn on.. i kno that my battery is charged.. because i charged it.. and all my other lights work when i hook up the battery.. i made sure that i grounded the ground wire on the wire harness.. is there anything else that im missing? i cant figure it out! does it matter where you ground the ground wire on the harness?? i didnt kno where i had to ground it.. so i just picked any bolt that was close.. unbolted it.. and grounded it.. i dont kno whats going on.. thanks
help with my swap
oh oops.. sorry i forgot to mention.. i dropped in a h22.. manual conversion.. the car doesnt turn over.. when i turn the key once.. nothing happens.. when i turn it twice.. nothing happens.. the radio doesnt turn on and none of the gauge lights go on.. when i try to start it.. nothing.. but i DO have power in the car.. the headlights can turn on.. and break lights and yeah..
Frost White CB7 Crew #26
turn your headlights on and and try to start the car, if the headlights dim you got short to ground.
you can also have a bad neutral safety switch, did you say you converted the car to manual?if you did, you should of somehow installed a neutral safetyu switch,i dont have a diar]gram now so i aint sure.
Heres how you bypass the swicth simply take a screwdriver and touch bith terminals on the starter (big one with one of the small ones).This should atleast cause the car to turn over.Make ysure you have the key to the run position
(you are pushing the cluthc in right?lol)
ILBB
edit:shit, the neutral safety switch aka clutch switch on manuals is on the clutch pedal.I dont know if it gets wired in when people do conversions...I jus confused my selfLast edited by Ilikebigbutts; 02-10-2006, 08:03 PM.People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
no.. im not missing any fuses.. i started a couple weeks ago.. nothing got taken out besides motor and ecu and all the useless stuff..Originally posted by timmy0toolyou might be missing a ground wire somewhere. i'm not entirely sure but double-check. are you missing fuses too?! sorry i could not help much.
and yea i tried pushing the clutch down.. but when i try to start the car.. i get NOTHING.. no response or anything.. when i turn it to 1 i get nothing.. to 2.. nothing.. the gauge lights should be going on and radio and all electrical stuff.. but it doesnt.. then when i try to start.. nothing.. everythings hooked up.. how many ground wires are on the wire harness??
this is really pissing me off.. cuz ive worked so hard.. and in the end.. this is what i get.. haha.. but yea.. i just want this fixed!!! havent drove my car in 2 months!!!!! first month.. axles were bad.. so didnt drive it.. then a month later.. started the swap.. and now im done.. i just have to start it but it wont!!
welcome to the club
it'll take a long time for you to drive your car, simply because you've never done this before(i'm guessin).I'm not riping i just did my first swap to about 4 months ago and i still always have somthing to fix.
In the end, it'll all be worth it because you learned so much,just dont give up.Now stick a screwdriver on the two starter terminal just to make sure the satrter aint the problem.
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
it really sounds like you have a ground problem. if NOTHING turns on ie: lights, gauges, radio that means NO POWER. double check everything. take your time you will get it.
as cpmike said to me when i did my first swap. its the most littlest things that effect such a problem. then when you figure it out you think to yourself, "wtf is wrong with me"
you will get it man, patience and observation will get you driving it again.
yeah man.. i was just thinking about that earlier.. it could the littlest thing.. if it is.. im gonna kick myself for that.. haha.. but what do you mean by sticking a screwdriver on the two starter terminal?
im thinking it might be a ground problem.. the lights DO turn on.. like the headlight, break light, and domelight.. but not everything else.. i get nothing when i turn the key.. im gonna take another looksey.. if not ima steal
another accord wire harness from the junkyard.. see if that'll work..
^^^god that is SO trueOriginally posted by excalibur02then when you figure it out you think to yourself, "wtf is wrong with me"
ok if no lights on your dash are coming on or anything - im assuming then you're also not hearing your fuel pump prime itself - that sounds like the ecu ground
theres a ground wire on your thermostat housing - its the easiest to forget - hell, i forgot it
hook that one up and go start your carLast edited by i'm the girl; 02-11-2006, 03:35 AM.
breathing is deadly underwater...
Well, do the headlights come on before you turn the key? If they don't then that indicates to me that you don't have connections to the battery. When I have a bad ground to the battery, it will usually power on headlights, but when I go to start it, it will flicker and turn off.
Make sure you have a fully charged, good battery. If the car has been sitting a long time, it will have discharged some. Check your ground to the block, firewall, as well as your positive cable and the connection to the starter. Chances are that it is something very easy.
