thurs car was fine. Then I got the bright Idea of taken my 4-2-1 cast header and downpipe off the a6 and put it on my a1. the a6 downpipe has o2 at its rear not like my stock mani, right there! Anyway the one that was in there I found to be faulty, had cel in car it came from, and so i hooked it up in mine to find this. Next day I swap my mani's o2 for the other and I lengthen that harness! Turns out the plug from the engine harness of my a1 is Identical to the plug coming from the old o2 from the a6 header (with the exception of the wires colours)! So I connect it raw, cel goes away but I have idle surge still! again it was fine on thurs before the swap! So i go 500km and spend the night hangin wit my friend, and wake up the next morn to tackle this task. I notice a leak, fuel, from the #4 cyl injector so I buy another, and replace it leak is now gone but car still surgeing and is idleing on only three cyl! I pull the fourth wire it which made no diff(no change in engine at all!) has spark and the plug is good! It runs...ok movin except the surge, I have tried the fiv/vacuums are good, swapped the ecu! I am lost need help bad! have Reset the ecu! Map? anybody have any idea? thanks!
idling on three cylinders?
Originally posted by bobertjuanalso, kinda of an obvious thing.. not tryin to insult you, but sometimes it slips the mind. check for the power and ground to the injector. check both while the car is running, pulsing ground and constant power. are you get a cel?
You have to be careful when pulse testing F/INJ's while the engine is running. The opening of a F/INJ independant of the ECU operation can be detrimental to the Operation of the Engine. There are the possibilities of Fuel Hydraulic Lock, Spark Plug, O2 Sensor or Cat Convertor contamination.
alright, there is fuel pressure in the rail, no cel's, pulled the #1,2&3 plug wires and it runs super rough then. The terminals are fine, as I stated in my first post thurs. it was perfect! Also if you read my first post you would see that I had already swapped in another good injector! So im left to believe its something ecu related! Spark plugs are fine, is getting spark! Could it be something with the o2 sensor? I did lengthen the wires so it would reach the back of the downpipe!? Also does anybody know which wire does what from the a1 engine harness? The o2 has white, green, two blacks(heaters) If I knew what their counterparts were i would factor that out! Ps at idle it kinda seems like its still getting some fuel, cause when I giver it smoothes out a lot! Im still saying could it be map or egr or o2(was and still should be workin)
WaC!
Originally posted by westsideaccord.. pulled the #1,2&3 plug wires and it runs super rough then. The terminals are fine, as I stated in my first post thurs. it was perfect! Also if you read my first post you would see that I had already swapped in another good injector! .. Ps at idle it kinda seems like its still getting some fuel, cause when I giver it smoothes out a lot! Im still saying could it be map or egr or o2(was and still should be workin)
Check for Intake Manifold Vacuum Leaks.
Check for Exhaust Leaks Pre-O2 Sensor.
Originally posted by westsideaccordalright, there is fuel pressure in the rail, no cel's, pulled the #1,2&3 plug wires and it runs super rough then. The terminals are fine, as I stated in my first post thurs. it was perfect! Also if you read my first post you would see that I had already swapped in another good injector! So im left to believe its something ecu related! Spark plugs are fine, is getting spark! Could it be something with the o2 sensor? I did lengthen the wires so it would reach the back of the downpipe!? Also does anybody know which wire does what from the a1 engine harness? The o2 has white, green, two blacks(heaters) If I knew what their counterparts were i would factor that out! Ps at idle it kinda seems like its still getting some fuel, cause when I giver it smoothes out a lot! Im still saying could it be map or egr or o2(was and still should be workin)
Since your spark plugs are good, you get spark to all cylinders, you get fuel pressure to the fuel rail, have a good injector in #4 cylinder...
1) Verify your # 4 injector is working from the electro-mechanical aspect of it (I assume it is, but make SURE)
2) If your # 4 injector works, then I believe you have a burnt valve or ring blow-by and are not getting proper compression in # 4 cylinder. What you do then is up to you. You will not get a CEL for this, from my experience. I have an Accord that the #3 cylinder is dead and I will find out when I remove that engine and install the built engine. Until then, I'll be running on 3 cylinders as it still starts & runs, it just doesn't have any ballz. Good thing I have another Accord to drive.
To f22-guru you say it could be caused by leaky mani before o2? I do have a small leak there would that cause the o2 to get an improper reading?
Yeah I pulled all spark plug wires but the only cyl that doesnt do anything is 4! So and also the engine has 6000 on a fresh rebuild so, I will test compression again, but due to the car still having power when I "giver" it says to me electrical/sensor...so at idle or low speed the o2 isnt getting all the exhaust by it but at high speed it sees more and werks accordingly!? Huh! Thanks! also i had said that mine doesnt idle fine, surges when warm and sputters at 1.5-2k before that! Ill try sealing my exhaust leek for now! I am goin to turbo soon trial #3 with a nice fmic! Dsm setup, and so for that ill need a compression test anyway! Peace
WaC!
Originally posted by westsideaccordTo f22-guru you say it could be caused by leaky mani before o2? I do have a small leak there would that cause the o2 to get an improper reading?
If it thinks there is more oxygen than there actually is then it will re-trim the ECU Fuel Cells accordingly. The O2 will think it's running excessively lean and add fuel at the next duty cycle. The Extra fuel added to the actual amount of intake air will affect the overall performance.
Originally posted by westsideaccordYeah I pulled all spark plug wires but the only cyl that doesnt do anything is 4! So and also the engine has 6000 on a fresh rebuild so, I will test compression again, but due to the car still having power when I "giver" it says to me electrical/sensor...so at idle or low speed the o2 isnt getting all the exhaust by it but at high speed it sees more and werks accordingly!? Huh! Thanks! also i had said that mine doesnt idle fine, surges when warm and sputters at 1.5-2k before that!
If the F/INJ was working OK and the Spark Plug was receiving the correct voltage but not firing the opposite would occur - (and NO it would not even itself out ).
A bad ground to the Cylinder Head could also cause havoc as that is where the Spark Plugs get their Grounding.
So now we can see how important correct grounding of the Engine components is critical to the proper running of the engine overall.
Also if you have a Vacuum Leak at the Intake Manifold it too will cause a Lean Misfire at Idle and just above idle. An incorrect operating EGR can do the same thing. In the end it can all be a vicious circle.
If all these problems are present at the same time then even after fixing one you could still have a misfire. This is where you start scratching your head.
If you are sealing up your exhaust with silicone, remove the O2 Sensor until the silicone cures as the fumes can contaminate the O2 Sensor.
To check for Vacuum Leaks it's best to get a spray bottle with water in it and spray around the Intake Manifold, Gaskets, F/INJ's and T/Body. If the engine stumbles at that spot then you have pinpointed the leak. Others suggest the use of Propane or Carb Cleaners etc, but they are highly flammable and the risk of a stray spark could be a costly, if not dangerous, exercise.
Cheer
Geoff
Top.. plug A6
Heater (-) (+) Between 10~40 ohm
Sensor (-) (+) Less than 0.1v
Bottom plug A1
Sensor (-) (+) Less than 0.1vLast edited by accordmaniac; 02-01-2006, 10:53 AM.1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
I have fixede the problem! It was none of the above! It just so happens that the gasket where the intake meets the head, had blew out a piece right above/behind that injector, thus the surge, and the reason it was fine on throttle etc. Thankfully my dad and I sprayed some starter fluid around the intake gasket areas to find the hole then we see it! I also had the one left over from my rebuild, cause we did not need to seperate the head then. My car is normal again! Now its time to get my turbo rebuilt so I can complete trial #3 Peace!
WaC!
Originally posted by westsideaccordI have fixede the problem! It was none of the above!
From Post #6
Originally posted by F22-GURUAlso if you have a Vacuum Leak at the Intake Manifold it too will cause a Lean Misfire at Idle and just above idle. An incorrect operating EGR can do the same thing.
Cheer
GeoffLast edited by F22-GURU; 02-06-2006, 11:12 AM.
