Note: car is under new ownership as of 8/16.
Boost_Lee (formerly known as 91accordexr33) 1991 Accord EX Sedan
Project Name: Throwback
ENGINE
Bottom End
• F22B1 Golden Eagle Sleeved Block
• 87mm Arias F22 pistons
• Crower H23 rods
• ARP rod bolts
• ARP main studs
• ARP headstuds
• ACL main/rod bearings
• TOGA high volume oil pump
• Kaizen Speed balance shaft elimination kit
Head
• F22a4 Sohc Non-Vtec Head
• Bisimoto Engineering Stg 1.2 Cam
• Bisimoto Engineering Adjustable Cam Gear
• Bisimoto Engineering Valvesprings
Turbo Setup
• Custom Mini-Ram Manifold
• Precision GT3076R
• Fast-Turbo Oil Line Kit
• Fast-Turbo vaccum block kit
• Tial 38mm wastegate
• Synapse Engineering Synchronic BOV
• AEM Boost sensor (boost by gear)
• Allstar Performance catch can
• GM 3 bar map sensor
Fuel
• AEM High Volume Fuel Rail
• Fast-Turbo Fuel braided line kit
• Aeromotive FPR w/ gauge
• Precision 1000cc Injectors
• Aeromotive 340lph fuel pump
Chargepipes/Intake
• PBTuning 74mm Throttle Body
• H23 intake manifold, IAB plate removed, gutted
• KMS EGR block off plate
• Bisimoto Engineering heat-shielding intake manifold gasket
• 3" chargepipes
• 3" K&N Air Intake Filter
• FMIC , 3" core, backdoor inlet, 3" outlet
Ignition / Cooling
• MSD 6a ignition
• MSD cap
• MSD Blaster SS Coil
• Trigger Box / Ignitor eliminated
• NGK V-power R5672a-8 3 step colder plugs
• Aluminum Dual Core Half-Radiator
• Flex-A-Lite electric fan
• 170-degree Thermostat
Weight Reduction/Removed parts
• Heater bypassed
• AC system components removed
• Power Steering removed
• EGR System Bypassed
• Cruise Control removed
• Emmisions box removed
• Charcoal canister removed
• Battery Relocation to bumper
• Stripped interior from B pillar back
TRANSMISSION
• Automatic-to-manual conversion
• Quaife LSD
• H22a M2A4 tranny
• Drive Shaft Shop lvl 2.9 axles
• Legal Speed Designs 6 Puck Clutch
• Legal Speed Designs Dragger Pressure Plate
• Forbidden Motorsports BB4 Prelude Short throw shifter
EXHAUST
• 3" downpipe
• 3" flexpipe
• 3" KTeller stainless steel exhaust
• 3" Vibrant Stealth dual-tip Exhaust
EXTERIOR
• 92-93 Front bumper
• Xenon Mild front lip
• Xenon Mild Sideskirts
• Rear Xenon Mild lip
• JDM 90-91 1-piece blackhoused headlights
• TSX Projector retrofit
• TSX 4300k HID setup
• JDM Powerfolding mirrors, relay/switch
• Red/Clear tails
• BlizzGrill
• LED rear plate lights
• BlizzShade
• JDM Window Visors
• OEM flushmount replica
• Repainted Seattle Silver
• Tegiwa engine bay washers (purple, blk bolts)
SUSPENSION / WHEELS
• 17" 5Zigen FN01RC - Matte Black with purple pinstripe
• BLOX Purple lugs
• XXR 15x8 et 0, gloss black, purple lip
• Mickey Thompson ET Street 235/60/15 drag radials
• Omnipower Street Coilovers
• Front and Rear camber kit
• Rotor over hub conversion
• Prelude VTEC 11.2" rotors, crossdrilled and slotted
• Prelude VTEC Calipers
• HAWK pads
• Rear disc brake conversion
• 4040 Prop. Valve
• Techna-fit Stainless Brake Lines F / R
• Rear drilled and slotted rotors
• Progress Rear Sway Bar
• Energy Suspension front sway bar bushings
• Energy Suspension front sway bar endlinks
• Explicit Speed Performance CB7 front 2pt strut bar
• Explicit Speed Performance CB7 rear 2pt strut bar
• Explicit Speed Performance CB7 Traction bar system
• Explicit Speed Performance CB7 adjustable front torque mount
• Explicit Speed performance CB7 motor mount kit (auto-to-manual)
INTERIOR
• Sparco Sprint V full bucket seats
• Bride Type MO seat rails
• Crow 3" 4pt harnesses in purple
• Wrapped headliner, purple fabric
• Harness bar
• 4th gen Prelude BB4 shift base
• Blox Gunmetal shift knob
• 92-93 Manual Seatbelt conversion
• OEM Integra Type R shift boot
• Red LED Dash Cluster with Wagon Speedometer
• Stewart Warner 2 5/8" Gauges - Boost, Oil Pressure, Water Temp
• MOMO Hub with generic Wheel and "H" Horn
• Purple NRG quick release ver. 2.5
AUDIO / ELECTRONICS
• Radio Delete
• Code Alarm w/ remote start and 2way pager
Engine Management / Tuning Electronics
• Hondata S300
• Zeitronix Wideband 02 LCD display unit
• Bosch Wideband 02
• Zeitronix electronic boost sensor
TUNE
• "St00pified" by Jason Herrera
FUTURE PLANS
• Prothane bushing kit or spherical bearings
• new GE block
• Rollcage or rollbar setup
• CF Hood and Trunk / painted
PICS
Engine: Fully Built F22A4 SOHC non-Vtec
Misc pics
R33 front and M3 sides pictured here
special thanks to ALL members on this board, especially carlos, antoine, todd, john[s], steve, mike[s], eric, francis, adam... all u guys
shortcuts:
new muffler: pg 17
new motor build up: pg 18
jdm 1 pieces: pg 18
GT3076R: pg 19
new rims: pg 20
new exhaust and video clips of car: pg 21
Cf Hood: pgs 24-26
new pistons: 30
traction bar w clips: 30-31
New FMIC: pg 31-32
Built motor after paint and machine work: pg 33
Assembly of motor: pg 36
Engine bay makeover: pg 39
Wiretuck progress: pg 40
Legal Speed Designs Clutch review: pg 40
Engine assembly previews: pg 41-47
Running engine pics: pg 48
New camera shots: pg 52
Dyno chart: pg 56
Sway bar endlinks/coilover install: pg 58
2-step video: pg 58
New pics: pg 61
Teardown: pg 66
Projector retrofit progress: pg 67-69
Manifold pics: pg 71-72
Bisimoto parts / head: Pg 74
Mock up pics with manifold: Pg 77
Blizzshade : Pg 93
Back-on-the-road pics: Pg 94
ENGINE
Bottom End
• Crower H23 rods
• ARP rod bolts
• ARP main studs
• ARP headstuds
Head
Turbo Setup
• Precision GT3076R
Fuel
Chargepipes/Intake
• 3" chargepipes
Ignition / Cooling
• MSD 6a ignition
• MSD cap
• Heater bypassed
TRANSMISSION
• Quaife LSD
• H22a M2A4 tranny
EXHAUST
• 3" downpipe
• 3" flexpipe
EXTERIOR
• Red/Clear tails
• BlizzGrill
• BlizzShade
• JDM Window Visors
SUSPENSION / WHEELS
• BLOX Purple lugs
• HAWK pads
• 4040 Prop. Valve
INTERIOR
• Harness bar
AUDIO / ELECTRONICS
• Radio Delete
• Hondata S300
• Bosch Wideband 02
TUNE
FUTURE PLANS
• new GE block
PICS
Misc pics
shortcuts:
new muffler: pg 17
jdm 1 pieces: pg 18
GT3076R: pg 19
new rims: pg 20
Cf Hood: pgs 24-26
new pistons: 30
New FMIC: pg 31-32
Dyno chart: pg 56
2-step video: pg 58
New pics: pg 61
Teardown: pg 66
Blizzshade : Pg 93
