I've seen the threads on using urethane to fill an existing torn mount; I tried a couple using Flex Seal liquid rubber (may not have cleaned them well enough, it didn't seem to stick well) because I already had it around. I have a large block of ballistic rubber I used to make body mounts for my 99 E350 van, so I thought I'd try to make a solid insert for my torque mount.
Tools Needed:
2.5 inch hole saw
68 mm hole saw (64.7 mm inside diameter)
1 inch drill bit or spade bit
Sharp blade of some kind (I used a sharpened putty knife)
Hammer
Remove the front torque mount from the car; this is covered in other threads in the DIY section.
Use the 2.5 inch hole saw to cut the remaining rubber from the large end of the torque mount. If it is not already torn completely away, cut the center metal bushing out of the rubber first. Use the sharp blade to cut the rubber off the center metal bushing.
20200404_094117_resized by Paul Kemme, on Flickr
I had smaller block of rubber already cut from the larger block. I cut the end of this piece to the thickness of the mount.
20200414_200308_resized by Paul Kemme, on Flickr
Use the 68 mm hole saw to cut a round piece from the rubber. I was only able to get about halfway through the block using a drill, even with lubricant applied to the saw. I then had to manually turn the saw to keep it from heating up. I need to figure out a better way to do this.
20200414_204809_resized by Paul Kemme, on Flickr
I used a grinding wheel to trim some flash and chamfer the outside edges some.
20200414_205525_resized by Paul Kemme, on Flickr
Using a little soapy water, I was able to press the rubber into the mount about half way; I then used a hammer to persuade it the rest of the way in. I didn't use any adhesive for this trial, but I suspect the interference fit will keep it in place.
20200414_210042_resized by Paul Kemme, on Flickr
Use the 1 inch spade bit to bore a hole through the rubber. Somehow, the 1 inch bit didn't bore a 1 inch hole, but I was able to manually start the center bushing (about 1.07 inches diameter) into the rubber, then a hammer (supporting from the opposite side) to drive it the rest of the way through. I didn't intend for this to be quite this offset; I'll see if it is a problem when I try to install it.
20200414_212750_resized by Paul Kemme, on Flickr
I could probably get several dozen bushings out of the block I have if any one is interested. I have several bad mounts that I may go ahead and repair.
April 17, 2020: Installed it last night, the offset actually just about centered it in the slot in the bracket on the engine. This was after I installed the Innovative rear mount.
Tools Needed:
2.5 inch hole saw
Hammer
