EXT : 1 of a kind HALO PROJECT
    I already sucessfully retro fitted 1 0em headlight with projector and square halo. Came out awesome. I am waiting on my new headlights to arrive. The old head light was for testing and fabrrcation breakthroughs. I had to by a dremmel and do some cutting . I only had to drill 1 hole. Alo it kit i bought featured dual halos. I had to ditch 1 because it was simply too big. Wait for pick updates.
    Ok you can see were i drilled the hole and why. I will fill it with waterproof silicone. Also you can see how the projector is mounted. The end of it is threaded. And it fits threw the existing hole. And i tighten the nut on the back then there is a braket to mout the h1 light blub. A lock spring is included but i didnt intall it because this is only a test headlight.
    This is the 2nd halo i discarded because its too big and i had to shave the bottom and top of the halo housing.
    a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed
    I will update this thread when i recive my new headlights and go threw the process.
      Cool! I always thought square or similar halos would look great and accent our car well.
      YouTube Clicky!!
        Halo Project
        Great work man! It matches our cars better I think. I would definately be interested in getting a set from you. Have you thought about adding or using the 2nd halo for a blinker?
          nice project I prefer the halo in the stock housing with no projector where did you get the square halo from and can you get them to switch different colors?
            On ebay i typed in projector retro fit on the search bar . The larger halo switched from white to amber but it didnt fit standing vertical.
              I can make a set i must warn i paid 100 for the projector kit and ibpaint about 114 for two new depo headlights
                finished product
