A problem I used to have with my car dying when low on fuel (all electrical systems still function) has returned recently. I want to run the symptoms and my prognosis by all of you before I go with my replacement.
Once upon a time, back in 2009 to 2012, the CB would die after being put in neutral rarely and sporadically. I would have to let it sit for about one to two minutes before it would fire up again. This would happen when fuel was low.
Just the other day, it happened again, out of the blue! I was exiting the freeway, it was low on fuel, I put it in neutral, and it died. I pushed it into a nearby gas station, waited two minutes, checked the fuel pressure gauge in the mean time (read zero), and then it would fire right up.
My hypothesis is that the fuel filter is clogging up. I'm sure the AEM 320 lph fuel pump is not helping in that department, which is why it has come back after a three year hiatus.
What do you guys think? I have the Wix replacement, and it's been all those many years with the same filter (since at least 2006), so I feel it is important to replace anyway. However, is a clogged, old fuel filter the culprit for the stated symptoms?
