So I set out to get LEDs for my aftermarket clear tails for the 5th gen wagon.
Looking over the options and being on a budget, I went with a different solution.
Posting this on a 4th gen forum because I figure you guys could adapt it.
I order 4 LED Arrows in red, they ran me $4.14 shipped from Hong Kong.
I then ran to Radio Shack and got 4 Diodes, and a package of 450ohm Resistors, for under $5.
I had electrical tape, wire, and silicone sealant laying around, kept cost down.
Heat your tail lights up at 250* for 12mins in your oven.
Pry your tail lights apart, be careful, take it easy.
Place arrows in your tail light, any way you want. I spread mine out.
Run wire through existing hole.
Wire.
Seal up the tail light, and seal up the hole for the bulb, enjoy.
Brake light on.
Reg tail light.
Wire.
Brake light on.
Reg tail light.
