I'm not sure where this goes I'm new to this forum site so... I lowered my 93 accord on some coilover sleeves it was only lowered about an inch maybe 1-1/2 inches, but when I started to drive it, it would shake. So we changed out the rack and pinon and all 4 struts and the front sway bar bushings. I drove it again and when I began to slow down it would shake. Back when we changed the struts out I looked at my tires and there were gashes in the tires. Not bad gashes but noticeable. So I raised it to what its at now. Im wondering how I would get rid of the piece of metal in the wheel well
Lowering my 93 Accord
This topic is closed.
First - Welcome to the site. Read the rules, enjoy it here. lots of info & lots of help.
Regarding your issue. Why didn't you troubleshoot anything?
It sounds like you just replaced random parts to eliminate the shaking? The initial shaking was caused by something that was loose. Lowering your car 1 1/2" shouldn't cause shaking or rubbing or gashes in your tires.
So at the first shake you should of jacked it up and spun the tires manually while looking under there to see what is going wrong. You should of also wiggled your tires (9&3 position / 12&6 position) to check for wiggling.
As for the piece of metal in your wheel well now. Well you'll have to explain that one a bit further. Everything under there is suppose to be there.
Some pictures would really help here.
Originally posted by Raf99 View PostFirst - Welcome to the site. Read the rules, enjoy it here. lots of info & lots of help.
My uncle shook the wheels at the 9&3 and the 12&6 position. I honestly don't
know what I would be looking for. I just recently got into working into my car.
I'm in Chattanooga right now and I live in murfreesboro so I'll have pics up
hopefully sunday to show you what I mean about the metal... I know its kinda
hard to understand what I'm saying sorry...
check to see that your axles have no play when you push it up and down. at the same time rotate the wheel and keep checking for play. I ran into an issue like this and never could figure it out. Went under there one day and noticed that it had play, as well as rotating in an oval LOL.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by qtipvenom View Post+1, also if the car is shaking when you slow down(braking) I'd check the brake calipers and rotors to make sure they were re-installed properly. NOt sure if the car was shaking prior to lowering it but warped rotors will definitly make your car shake.
Originally posted by accordztech View Postcheck to see that your axles have no play when you push it up and down. at the same time rotate the wheel and keep checking for play. I ran into an issue like this and never could figure it out. Went under there one day and noticed that it had play, as well as rotating in an oval LOL.
What kind of coilovers and what kind of struts?
Also did you ever try replacing the tires?
After lowering it did you get it aligned?1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostWhat kind of coilovers and what kind of struts?
believe they are just generic coilover sleeves though. Also the struts are just
some gabriel ultras you can get them at autozone for like I think 50 for back and
54 for front. Also I haven't got it aligned yet I plan on getting it aligned this
weekend if I have the money.
Originally posted by SleeppyAccord View PostThey are just Coilover sleeves that came with the body when I bought it I
1. Don't use generic coilovers.
2. Don't use generic coilovers on OEM or factory replacement struts.
3. You must get an alignment anytime you repair or replace anything in the suspension or steering system.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostEverything you just wrote is why your car handles the way it does.
Originally posted by 5ivescb7 View PostTry puttin new tires on and if ur gonna go with cheap sleeves buy some good struts it will definetly help like kybs ground control somethin respectable it will help alot
Bottom line, NEVER USE CHEAP SUSPENSION COMPONENTS... Also Ground Control doesn't make struts, they resell struts, usually Koni, they don't even make springs, they use Eibach. Ground Control makes sleeves. New tires on incorrect cheap springs with worn/bad/cheap suspension just means you fix nothing and throw more money in the trash in the form of tires.Last edited by wildBill83; 07-27-2013, 07:12 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by RoseRoyce View PostI wonder u he got banned?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
