Old 04-25-2013, 08:55 PM   #1
bseballkid1990
bseballkid1990 is cool... so far.
Does anyone else have a leaky trunk?
I get a puddles when i drive in the rain but it's not as bad when it's just sitting there. I've looked everywhere and sealed where the tail lights mount
bseballkid1990 is offline   Reply With Quote
Old 04-25-2013, 09:17 PM   #2
fleetw00d
You would do well to search some, there are numerous threads about water in the trunk. Along with leakage past the tail light gasket, other possible sources are through the tail lights themselves, the trim clips at the base of the rear window, the bumper cover support clips (supports the top of the cover haldway between the wheel well and the rear corner), the vent on the left side, the antenna hole, bad trunk gasket, rust through in the rear wheel wells. Remove your trunk lining, drop the back seat, and look inside the trunk as a helper sprays water over the rear of the car.
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 384,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - you need it? you can have it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 04-25-2013, 09:26 PM   #4
bseballkid1990
Damn, I didn't think there were that many different scenarios lol
Old 04-27-2013, 09:51 PM   #6
CameDaCB7
CameDaCB7 is cool... so far.
I changed the tail light gaskets on my 91 accord with these,
http://www.ebay.com/itm/190821035037...84.m1423.l2649
No more water in trunk afterwards, even after the big flood rain that recently took place in Chicago.
CameDaCB7 is offline   Reply With Quote
Old 04-28-2013, 02:21 AM   #8
ShiroiKinCB
ShiroiKinCB is cool... so far.
Same boat
ShiroiKinCB is offline   Reply With Quote
Old 04-28-2013, 10:30 PM   #9
#1_M.I._CARLOS
#1_M.I._CARLOS is cool... so far.
Most of the time it's gonna be your tail light gasket or the trunk seal gasket. I bought some JDM tail lights and the gaskets were different, left some big openings and my trunk was getting full of water. Changed them to oem gaskets & fixed the problem
#1_M.I._CARLOS is offline   Reply With Quote
Old 04-28-2013, 11:55 PM   #10
ShiroiKinCB
What? Jdm taillights?
Old 04-29-2013, 01:01 AM   #11
#1_M.I._CARLOS
They are the chrome lining oem tail lights and the figment to usdm cb's sux
Old 04-29-2013, 09:44 PM   #12
fleetw00d
Voice of experience, I've think I've had them all except a bad trunk lid gasket (the lip it is mounted to was rusting on my 90, but it wasn't leaking into the trunk). Also make sure the drain tube from the bottom of the antenna motor is properly connected to the drain grommet on the left side. Couple other places I have seen on my Accords: leak from the gas filler area; body seam above the left tail light, evidence of leakage around the bottom clip for the chrome behind the rear door opening on a sedan (streaks on the inside of the quarter skin I noticed when replacing the quarters in my "Rescuing Ruby" project).
