I don't know if my car has a exterior leak somewhere, or if CB7 EX-R's tend to rust where the spoiler is attached, but there is always a huge amount of water in the trunk after wet days and it is dripping right onto my sub box, causing it to grow black mold. Not really a fan... Anyone have similar problems with moisture/trunk leaks, and know how to fix it?
Moisture in the trunk
Originally posted by Revious View PostI don't know if my car has a exterior leak somewhere, or if CB7 EX-R's tend to rust where the spoiler is attached, but there is always a huge amount of water in the trunk after wet days and it is dripping right onto my sub box, causing it to grow black mold. Not really a fan... Anyone have similar problems with moisture/trunk leaks, and know how to fix it?
common problem
https://www.google.com/#hl=en&q=+sit...w=1441&bih=656
get some mouse pads and cut them to the shape of your tail light gaskets. it helped me. i had puddles on each side behind the tail light.
or maybe in your case might be coming from the spoiler gaskets since you say its rusting. do you know if the spoiler was an add on from the dealer or added later?
C-3PO's MRT USDM yo!
I had the same thing cept it was in the tire compartment of my wagon. I have no idea how all that water got in their either it was weird.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
The water in your taillight and probably your trunk is from the taillight gaskets. There are several DIYs of fixing that problem. The Spoiler issue is a common thing too. If you plan on keeping it, remove it and clean area, rust, old gasket material, make up some new gaskets and use some silicone the middle bolt, the other two drain into the trunk gutters.
Did you have some snow on your trunk and then have milder weather?? or maybe just some milder weather, I C your in BC. My buddy had the same moisture all on the underside of the trunk, I think it was from a dramatic temp change.Last edited by DanCan; 03-14-2013, 11:30 PM.
Originally posted by DanCan View PostAll that water on the underside of the trunk is definitely from condensation.
Originally posted by 91cbminn View PostI would make a gasket to replace the bad one and then use some silicone to seal it.
I've already done a bunch of work to the car with some major help from car-savvy friends. For instance when I got it the previous owner hid wheel well rust with bondo. We ripped all that out, put new new metal in, welded it up and filled that sucker up with allmetal. Shouldn't rust ever ever again.
Originally posted by CB7 Coupe <3 View PostHappened to mine after some thieving F*cks tried to rip my spoiler off after they stole my car an gutted it. They also bent the trunk lining yanking the 15 box out .. So it leaks in two spots.
Does anyone know how I got water (like a good amount) in my tire compartment of my wagon?“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
