Ideas for AWD CBs! Motors? Drivetrains?
    This thread is, now, for thoughts on AWD CBs. Post your thoughts on different motors, Honda or other, drivetrains, etc. What do you think would be cool? What do you think would even work?
    I was thinking the other day about swaps and conersions and what not, and this came accross my mind. so I am seeing what people think. Evo VIII\IX motor, trans, and drive train in a 92\93 CB7. Sleeper, if you will. AWD. Turbo. I think it'd be awesome. Ideas?
    VTEC by birth, not be choice.
    Andy's Auto Sport: Comptech Battery Tie Down, "It will look so trick that your car will think it has more horsepower!"
    DumbleDore!'s CG
    http://www.cb7tuner.com/vbb/showthread.php?t=199312
    I mean, Anything is possible if you got deep pockets....
      The cheapest easiest most dependable way would be buy an EVO and fit a cb7 body. If not we are talking fractions of a difference. With the tools I currently have at disposal I think that's how I would do it.
      ......father in law has it back again. Time to shine
        Look up AlmostJDM's RWD conversion project. Converting a CB7 to AWD would be just as complicated, if not more so.
        Could it be done? Sure. Would it be worth the effort? Perhaps. You'd certainly have something unique, provided you can actually make it work reliably.
        Personally, if I wanted an early 90s midsize family sedan with AWD and a turbo 4g63, I'd just buy a Galant VR4. Hell, it'd probably be cheaper and easier to make a Galant VR4 look like a CB7 than it would be to convert a CB7 to run an Evo engine and trans!
          I'll have to check it out. It's not so much wanting an AWD 4G63 sedan, I could just buy an Evo, I want an AWD 4G63 CB7. ;]
          DumbleDore!'s CG
            Aside from all of this and awd the notion is nice putting it into a cb7but there is a factor remaining. The evo's chasis. There are so many bars on that car and reinforcement which makes the car very stiff in turns along in conjunction with the suspension. So evernthough you want awd make sure the handling is there.
              Precisely.
              The way CB7 would need when hacked up to accommodate a rear driveshaft and driven rear wheels, adequate bracing would pretty much HAVE to happen! In fact, with an extensive project like that, I'd suggest welding all the seams in the unibody (cut the tack welds and do a solid weld), and install a full cage. Now, a full cage isn't exactly safe on the street (you can hit your head on it.) That automatically takes all practicality out of such a project. The CB chassis would need the support, though, because even before you gut it like a fish to make a driveshaft tunnel, the rear of the car isn't built to handle any sort of torque. There's no twisting going on back there, so it was never reinforced. Any power going to the rear wheels will tweak the chassis terribly without bracing the car properly to handle it.
                It would be cheaper to get a used EVO VIII
                Originally posted by lordoja
                  It might be cheaper to get a new EvoX!
                    All good thoughts and points, the reason I posted this. Shame, would have been a cool project. We'll see, although it sounds like I need a new idea. Haha
                    DumbleDore!'s CG
                      You could still pull it off with careful planning, lots of trial and error, and at least twice the amount of money you'd expect to spend initially.
                      It's far more involved than simply bolting up new parts and fabricating some mounts, though.
                      Try tossing a FWD 4G63t setup in there first. If you can get that to work properly, then you could look into using DSM parts to add the AWD.
                      Or you could be even cooler, and adapt the Mitsubishi AWD system (or whatever system you like) to be used with an F22A
                        If I were to do that, I'd use an F22B.
                        DumbleDore!'s CG
                          Why?
                            Why?
                            Facepalm My bad, F20B. http://www.jdmenginedepot.com/jdm_en...mission,_&_ECU
                            DumbleDore!'s CG
                              Even worse. Why?
                              And from that place? Good luck. You live in CA, why the fuck do you want an engine from NJ? I live in NJ, and even I wouldn't buy an engine from them! Buy from hmotorsonline.com if you want something worth installing. I suggest H22A if you want to swap at all (the F22A has a ton of potential, though...)
                              The F20B was never sold in the US, so finding parts for it that aren't shared with the H22A is tough. It is OBD2, so you'd never be able to use a proper ECU for it unless you convert your car's wiring to OBD2. The F20B came in two varieties, 180hp and 200hp (a little less on both counts, but that's the easiest way to put it.) From most resellers, especially the shady cheap ones like jdmenginedepot, you'll probably end up with the 180hp version. 180hp and low torque due to the 2.0L displacement... that's a turd. Honestly, not a whole lot better than the F22B.
                              Yes, the F20B was designed for racing. It was designed for a class that was limited to 2.0L. It's not a racing engine... it's an engine that was designed under considerable restrictions.
                              And it's common enough that it's not very "different".
