Disclaimer: This is my first tutorial so if I made some errors or was not clear enough please do not flame me.
Thanks....
Installing Projectors on a 1992 Honda Accord Coupe Ex…..
Removing the front Bumper
1. Remove the two bumper bolts as seen in pictures A and B. There is one on the left and one on the right side(Pictures C,D). I removed my battery and radiator overflow for this so it was easier to remove the bolt. The driver’s side bolt can be reached with a socket. As for the passenger side, an open end wrench must be used, and it is very tight spacing so you must have some patience with it. I believe both the bolts are 12mm.
A :
B :
C :
D :
2. There are two screws on the both sides (total of 4) in the inner front fenders that must be removed. (Picture E)
E :
3. Next, the bumper lights can be removed by a simply unscrewing a screw (Picture F). Make sure you take both off. There will be a connector that you must disassemble to remove the lights completely (Pictures G and H)
F :
G :
H :
4. There are “quick clips” (Picture I) (15 or so) underneath the head lights and all the way across the top of the bumper that I am not sure I had to remove or not. I don’t think you should have to. If when you try and remove the bumper and there is a lot of resistance from them you can remove them. The only reason I was able to get to them was because the previous got into an accident and the bumper is bent slightly down. I don't think you would be able to if you front end was not damaged.
I :
Thanks....
A :
B :
C :
D :
E :
F :
G :
H :
I :
