Hello. This is going to be quick and simple. The hardest part may be picking out what color tubing you want to use.
Reason for this was to replace the old brittle tubing that broke on me when I swapped over to cd accord nozzles. I had this stuff laying around. If you don't go to your local hobby store that sells nitro rc supplies. I only replaced the two pieces of tubing that lead to each nozzle. Not the entire thing. If you look under your hood, you'll see that the single tubing coming from the inside of the fender splits in two.
nitro rc engine fuel tubing
nitro rc engine fuel filter
scissors
tiny zip-tie
Carefully pull off each hose
Compare your fuel tubing to your old tubing and cut to length
Slide the new tubing onto the original fittings
Add zip-ties to each end
I went almost an inch before the Y fitting. Made a cut, and slid in the fuel filter.
And that's it! Enjoy a little more uniqueness under your hood and not having to clean out your nozzles again. Thank you!
What was used
scissors
tiny zip-tie
