after filling my mount with Windo-Weld Sealant and 1 month later having it melt,this is what i made,so far its been holding up great and looks way better then the stock mont, kinda after market. total cost about 35 bucks.i should of took picks when i was actually making it, sorry guys
parts neede
1-tractor top link bar (short) stock mount is around 1ft long (tractor supply)
2-1/2 washers (tractor supply)
4-rubber stoppers got these at osh forgot the size but the bigger ones are the same size as the washers,other 2 are for the bottom part so they wll need to be smaller sized,i used some bushings i had laying around so i wouldnt know what size
you will have to cut i belive 1 1/2 off each side of the cylinder and bout 3" off the bolt from the cylinder, u can do both but i did one since i used a hack saw to cut them and my arm got tired.
this is what you shoul have
you can also paint it to give it a nicer look or polish it
now you ar going to trim off some (FAT) off the rubber stoppers so that they will go in smooth when you have everything on the mount support.i heated a bolt to make the middle holes on the rubber stoppers
i put the washers at the end of the rubber stoppers
now for the bottom part u will aslo need some rubber stoppers i had some small bushings laying around i just cut the sides of them to make them fit
finish
parts neede
finish
