My suspension/brake/wheel upgrade with 5-lug conversion
    I completed my suspension/brake/wheel upgrade this past weekend and did some fine tuning this morning. I've finally gotten everything finished enough to the point that it's a reliable driver. Pretty soon, though, the knuckles are going to come back off to have new wheel bearings and lower ball joints installed and I'm going to put a new set of calipers back on.
    Here's the list of the most recent round of work:
    Function & Form Type 1 coilovers
    '99-'04 Acura RL 11.8" rotors and caliper brackets (same as '99-'03 TL and '01-'03 CL)
    '93-'95 Legend coupe dual-piston calipers (will soon replace with a rebuilt set)
    '96-'99 Isuzu Oasis front knuckles (same as Odyssey)
    '96-'98 Acura 3.2TL rear knuckles (modified for the CB7 but I'll detail that later)
    '92-'94 Acura Vigor 16mm rear sway bar
    new inner/outer tie rod ends
    new upper control arms
    urethane front lower control arm bushings and sway bar end links
    urethane rear sway bar mount bushings modified to 16mm
    '04-'07 Hyundai Sonata 16X6.5" wheels
    Michelin MVX4 205/55/16 tires
    A few of you may remember the way this car looked when I bought it from this thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=184935
    It was lowered in the front on cheap coilovers and had factory blown shocks all around. The wheels were very heavy 17X7" 7-spoke Motegis with cheapie tires on them. The control arms and bushings were mostly shot and the only thing I could do was replace the shocks and springs all around with some Progress springs and Monroe wagon shocks I got from da9b16. I wanted them to last me a month or two and Houston roads didn't even let that happen. All 4 of those shocks blew within 2 weeks in the inner Houston roads. They weren't perfect when they went in but I'm living testament to why that is never a good idea when lowering a car. The roads around here also bent one of my rims for me. This was partly due to the fact that there was no shock to absorb impact.
    Fast forward a few weeks:
    I had slowly been accumulating stuff to throw on and due to the problems I faced with the roads I parked it at my parent's house. I wanted to go 5-lug but I wanted to experiment with different methods. Tippey764 and I discussed other methods of doing the front but because of time and resources, the knuckles I was planning to use have been put on hold. For now I'm using Odyssey/Oasis front knuckles.
    I was, however, successful in coming up with a rear knuckle swap that provides the community an alternative to the 5th generation Prelude hub/bearing setup. I used the entire rear knuckle/hub/bearing/rotor from the '96-'98 3.2TL. It is nearly a direct swap for coupes or sedans and IS a direct swap for wagons. It would also easily swap over to all '94-'97 Accords, Vigors, 1st generation CLs, etc., but that's another discussion. The only "downside" to this is that the hub is 30mm taller on each side so the rear track is effectively widened by 60mm. Whether or not that is beneficial to your performance or aesthetic goals I will leave for you to decide. I have plans for mine so I don't care that it currently extends beyond the arches. The reason this needed to be modified for the CB7 but doesn't for the CB9 and other cars is because of the spacing (front to rear) of the rear lower control arms. The through bolt is likewise longer through the knuckle and there is extra material on the knuckle as well. I just cut the additional length off with a hacksaw and bolted it up no problems. If you wanted, you could also use the corresponding rear lower crossmember that would match the control arm spacing of the new rear knuckles. I'll likely do it all over again in the future and go this route.
    The front brake setup was something I came up with reading around on the internet for different rotor dimensions. It's the 11.8" rotors from the '99-'04 RL. I don't claim to be the first to do it at all, but I see people stick with 11.1" most often. Even 11.1" is probably overkill for these cars for regular driving but I wanted something bigger for track purposes and these fit the bill. They are 28mm wide and require you to use the caliper bracket from the same car.
    I picked the Function and Forms because they're adjustable and all four corners needed to be replaced. I had also heard that they were comfortable. Comfortable is probably a stretch but they're certainly nice around curves and corners. The rear sway bar helps immensely here as well. I need them to be high up for the roads and speed bumps around me so I don't care if you think it "needs MOAR LOW!!"
    Finally, the MAIN reason for going 5-lug.. I'm a huge fan of the 6-spoke wheels that '92-'93 EX coupe and 10th Anniversary sedans had. It's just a classy looking wheel. But, they're narrow, they're 15" and most notably my car didn't come with them when I bought it. I saw these Hyundai Sonata wheels and was sold immediately. I think the extra inch of diameter and lack of lug nut cover updates the look a lot. The extra width helps with performance as well, though not so much with fuel economy. Basically, it was a way for me to have the look I liked, but do it a little differently.
    Here's how it sits now.
    Dam that's nice. Wheels tho.
    She stops on the money and gives change back!!!
      Very cool right up. I see what you mean about the TL knuckles, but I`m interested in the dyi. Good job though.
        The 5 lug conversion is a bit difficult to get done but once its over, its worth every effort. I get a ton of compliments on it lol.
        Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
        My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
        Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
          dude thats really a sweet set up. i think the work was worth it in the end results.
          Accord SE
          93se
          Members Ride
          Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
          Sold to: sulimed, BurtonRiderT6, tishock
            Why do the rear wheel stick out so much? Spacers? staggered?
              Looks mean, will be better once you get those fender mods on you were talking about. Sorry I didn't help you bleed your brakes. Got the other motor mount on order today, had to send picture proof... Thanks for the help this weekend, BTW I got 27MPG, but only after leaving some gas in your driveway LOL.
                It's all relative. I would have done close to the same amount of work simply replacing the components that were damaged from bad roads or age as I did doing all of the upgrades. A few extra things but nothing I lost too much sleep over.
                I addressed why the rears stick out in the first post. It's not a 5th generation Prelude 5-lug rear conversion and is one of the primary reasons behind this post.
                My plans to foil your mileage seem to have worked. There's just something inherently wrong with you getting better gas mileage than me with an automatic, working A/C and driving 85mph. My engine has less than 2000 miles on it at this point, it has a rebuilt 5-speed transmission, I drive 70mph on the highway and don't have working A/C. Needless to say I'm some combination of baffled and upset.
                  Did you use the rl caliper or the legend? I'm assuming that if you got the rotors a day brackets one could use the oddy/prelude single piston caliper?
                  COUPE K24
                    I used the Legend dual-piston caliper. You can use that one or the larger single-piston. Since the rotors are 28mm wide you'll need to either use the Legend pads or '99-'04 RL pads depending on whether you use 1 or 2-piston calipers. The pad has a surface for the pistons to clamp down onto.
                      Will 1998 parts work? Mainly the brackets?
                      COUPE K24
                        Care to elaborate on what vehicle from 1998 you're describing?
                        EDIT*
                        Instead of waiting for a response I'll assume you were asking about the '98 RL. My previous source listed the '99-'00 RL as having the 11.8" front rotors but in actuality it's the '99-'04. I've adjusted the original post to reflect this. The '98 (specifically, '96-'98) uses 11.1" rotors up front. It's identical to the '91-'95 Legends and '96-'98 3.2TL in term of front suspensions.
                          Rl sorry. Guess I'll just wait for the right year to show up.
                          COUPE K24
                            UPDATE*
                            The wheel issue in the rear is fixable by using the wheels from a '91-'95 Legend or the '96-'98 3.2TL. I didn't know this at the time I was doing mine. What this means is that the rear wheels from an S2000 would fit on perfectly flush as well because of their offset. You have the member coupes to thank for this. He did it with Legend wheels on his using the same rear knuckles as me and his is totally flushed up in the rear. I have pictures of the fitment on his car but I'll ask him before I post them.
                            I think I may end up swapping back over to my rear discs knuckles and using Prelude hubs since I've bought them already. But I wanted to share this for anyone who decides to use the 3.2TL knuckles still. Give coupes some rep points on some of his posts for this as it has eliminated the only real negative to using this method for rear 5-lug.
                              i have to ask you. i did the RL upgrade, but reused my Ody front calipers and pads. if you look at the rotor, it looks like there is a part of the rotor where the pads aren't even touching. if I use the legend dual piston calipers/brackets, will it make full contact with the rotor?
                              COUPE K24
