So tonight I went to move my car from my street into my drive way and check engine light would reset and my car would just shut off. I did earlier that day take my distributor off to change my heater hose since it was leaking. Is there anything anyone would kno what the problem could be in this situation? To me it seems like. To me it seems like my ecu is restarting and then just shuts off on me.
Car keeps shutting off
Originally posted by deevergote View PostWhat do you mean by "check engine light would reset"?
I was wondering if you are still having your problem. We seem to be having the same symptoms; Where the CEL flashes, reseting the Main relay, which disrupts power to the fuel system, ergo, car dies while driving, or does not start.
If you have not already, I would first check the main relay. It is a very common trouble maker on the 4th and 5th generation accords, (after over 18 years of working fine, not bad). You do not need to buy one as long as you can solder. But with the discount code "RETMENOT123" you can get one from advance for less than $40. and it has a lifetime warranty, so if it is not the problem, you can get your money back.
Even though we have the same symptoms, I hope the main relay is your problem, it wasn't on mine, I soldered mine 4 months ago, and popped a new one in last week, and am still having problems.
good luck,
Ken_
Originally posted by KB7 View PostI was wondering if you are still having your problem. We seem to be having the same symptoms; Where the CEL flashes, reseting the Main relay, which disrupts power to the fuel system, ergo, car dies while driving, or does not start.
good luck,
Ken
