Wind noise when driving on highway
    Car is a 91 ex-r, sedan.
    I've noticed that there is a lot of wind noise when I take my car out on the highway, speeds of 80km/h+ will do this. I haevn't been able to check which window it is because I drive myself on the highway and you know, safety etc. But, I'm pretty sure it's my driver door as I put my hand near the corner of the window (near B pillar) and notice the noise went down a bit.
    Do you guys have any ideas on what I can do to reduce / eliminate this noise? I'm thinking of somehow slipping something to close the gap that is probably causing this noise. Throw out some ideas for me please, thanks!
    Replace the door seal......
      ^^word^^
      also when the window regulators start to go, the window will go up a bit crooked, therefore not sealing correctly........get another set of hands and have one person hold both sides of the window toward teh back(b pillar side) while the other hits the button to roll it up......my driver side is fubar and i get this all the time
        http://www.hondaautomotiveparts.com/...ONT+DOOR+GLASS
        Part 15 right?
        darkslide: That's a good idea, I noticed my driver side power window is "weaker". When the window is all the way down and I hold the up button, it will go normal speed, slow down when it reaches half way, slow but keep going up, then once it's near the top it speeds up a bit back to normal speed and closes.
        I'll have to give that a try.
          is a pretty common cb7 ailment from what i understand
          and fushigi was talking about the complete door seal.....betweent eh door and the body
