EDIT: THREAD UPDATE TO THIS OLD ASS THREAD HERE: (bottom of the page)http://www.cb7tuner.com/vbb/showthre...=168323&page=3
Hello,
I'm new to Accords and new to this site, but some friends and I are currently building a 93 Accord for the 24 Hours of LeMons race at Buttonwillow Raceway this December.
It's a 24 hour endurance race for beater cars, totally for fun and the limit on the "worth" of the cars is $500. If you want to know a bit about it, check it out here:
http://www.24hoursoflemons.com/
So my friends and I got a decent 93 Accord 5 speed with F22A1 and 200,000 miles for free and decided to run this race we've all been wanting to do for a while.
Since the car ran pretty much fine as it was, the basic plan was to strip it down, lighten it as much as possible, install a roll cage, racing seat/harness, install some decent front brakes, no whatever we could to the suspension, tune up the motor and go!
Since the limit on cost is $500, there's not a lot of expensive parts we can throw on it, and most of the mods we have to do are pretty hacky. For instance to get the suspensions stiffer and lower, we're going to cut 3 or 4 coils off the springs. To get a bet more intake flow, we chopped up the airbox, etc.
Luckily I'm a pretty experienced mechanic, but my main car interests are VWs, Porsches and Miatas. I did used to have an 88 Integra though so at least I'm a bit familiar with Hondas. Since none of us really know anything about Accords, I'll have a LOT of questions, hopefully you guys can help us out
Here's ow it stands now:
Yesterday I started to gut the doors
and this is what came out of one rear door:
Here's the seat/harness:
and here I am welding up a gas pedal stop since we removed the carpet and everything, the pedal was moving way further than it should've:
Click here for the full 1280x960 image.
I have three first questions for you:
--Ignition Timing--
We'll be running 91 octane gas at the race track, about what should I set the ignition timing to for max power without pinging?
--Balance Shafts--
I'm going to replace the timing belt this weekend, is it okay to completely leave the balance shaft belt off to gain a bit of power? This won't screw up oil flow/pressure?
--A/C Removal--
We've already removed all of the A/C lexcept the compressor. If I want to ditch the compressor, can I just remove it and get the correct length belt to fit between the alternator and the crank pulley?
Does anyone have any other super cheap/free mods that would be a good idea for this car?
Thanks! I'll keep the thread updated as we finish the build and go racing!
Hello,
--Ignition Timing--
--Balance Shafts--
--A/C Removal--
