I found 3 engines im considering swapping in here are links to em:
F20B from an Accord Type R
http://japanesestarmotor.com/jdm_engines/16/Honda_f20b/
DOHC VTEC Manual Version:
* 197 HP @ 7200RPM
* 145 TQ @ 6600RPM
* 147.10 kw
* 11.0:1 CR
* 85mm bore
* 88mm stroke
* 23mm wrist pin
* 145.5mm rods (f20b rod length = 145.425)
* 1.65 r/s ratio
* 55mm mains like h22a4 block
H23 Non VTEC
http://japanesestarmotor.com/jdm_eng...honda_prelude/
* Bore × Stroke: 87.0 × 95.0 mm (3.43 × 3.74 in)
* Displacement: 2,258 cc (137.8 cu in)
* Valve Configuration: DOHC, 16 valves
* Type: In-line 4 cylinder, aluminum block and head
* Compression ratio: 9.8:1
* Max power: 170 hp (127 kW; 170 hp)
* Max torque: 156 ft·lbf (212 N·m)
* Redline: 6500 rpm
* Engine Control System: Honda Systems PGM-FI with port fuel injection
* Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
H23 VTEC
http://japanesestarmotor.com/jdm_eng...da_h23a_v-tec/
In 1998 Honda produced a rare VTEC version of the H23 engine for use in Japan only. It is essentially an H23 block with an H22 head. The power is on par with a typical H22 engine but with a lower redline.
Specifications
* Bore × Stroke: {{
* 1998-2002 Accord Wagon AWD (CL2). It produces 200 PS (147 kW; 197 hp) & 163 ft·lbf (221 N·m) and comes with a "blue top".
* 197 HP @ 7200RPM
* 145 TQ @ 6600RPM
* 147.10 kw
* 11.0:1 CR
* 85mm bore
* 88mm stroke
* 23mm wrist pin
* 1.65 r/s ratio
H23 Non VTEC
* Redline: 6500 rpm
H23 VTEC
Specifications
* Bore × Stroke: {{
