What camber kit do you guys have? There are a lot to choose from and i just wanna know which ones you guys run Thanks
Koni supercup kit
Originally posted by 91cblx View PostWhat camber kit do you guys have? There are a lot to choose from and i just wanna know which ones you guys run ThanksThere are no black and white suspension answers!!!!!!!!!!!
I have this setup. Ingalls front anchor bolt camber kit, works fine for me. All shocks are set at middle perch. I used washer trick (2 per screw) for rear. Alignment was in spec all-around afterwards.
You will need the larger degree range 1.5-3 deg (if memory serves me right). Get the rubber bushings for less squeak noise on inclines, I have the poly and they do that every now & then.
