Cold Air intake?
This topic is closed.
    Cold Air intake?
    I've seen everything from hand made to high quality parts!
    What have you done, and what did you find works well?
    Bought From:
    CB7 Sleeper
    illestatus
    HondaFan81
    My Ride:
    http://www.cb7tuner.com/vbb/showthre...92#post2587592
    i have an ebay CAI
      I just installed a aem cold air intake, not a real noticeable difference except the sound. Alot of people here suggest just going for a short air instead. It all depends what your looking to get out of it.
      Don't Act Like You're Not Impressed!-Ron Burgundy
      Gamertag journeyman846
        If you want sound, go with an aftermarket aluminum piped-big ass cone filter type intake.
        If you want performance, get the TAS drop-in hybrid intake, and bisi manifold gasket kit.
        If you want both, get a snail
        Personally, I always go back and forth between my stockbox with AEM drop-in filter, or my cheap shitty ebay pipe.
        life is good.
          Right now I am just looking for sound. Would I be better of going for a short air?
          Bought From:
          CB7 Sleeper
          illestatus
          HondaFan81
          My Ride:
            you could just fit a cone filter in place of the stock box, it makes the sound a little deeper than stock
              Would you recommend going to eBay for something like that? or going new?
              Bought From:
              CB7 Sleeper
              illestatus
              HondaFan81
              My Ride:
                I see it this way an aluminum tube is an aluminum tube no matter what they name of the brand is. Anything is better then the restrictive stock intake system. (unless of course you modify the stock system to be less restrictive)
                I think the TASpro Hybrid intake looks good and great price! (best of both worlds.)
                Just my opinion.
                  Just my opinion.
                  Thanks!
                  Bought From:
                  CB7 Sleeper
                  illestatus
                  HondaFan81
                  My Ride:
                    i just dropped in a aem sri and i love it. noticable change in tone, my cb sounds meaner on WOT and the noise it makes as it sucks in air is nice to listen to haha. performance wise it doesnt do a whole lot but im sure it helps a little here and there
                      splitting hairs for a f22. only intake i've seen that would work on our cars that made any real power was the aem v2 on the h22.
                        Iceman thermoplastic dynamic chamber intake. Its made out of a heat resistant plastic so its very resistant to heat soak when the car is idle. Its got a large 4" opening at the filter and tapers down to the exact size of the throttle body to force the air in the plenum and runners.
                        Good luck finding one, they went out of business over 7 yrs ago. I'm still looking for the lower portion that attaches to the intake to make it a true cold air. So right now I've got to settle for the short ram version it is now.
                        member's ride thread
                        91 Accord SE 176k
                          i just went to pepboys hah
                          and fit a coupler to it
                            I recommend Spectre Filters.
                            As for piping...piping is piping unless you wanna split hairs. Use stock or aftermarket, whatever.
                            Originally posted by Jarrett
                              also keep in mind, that with a true CAI, you have to enlarge the hole in the battery shelf to fit the pipe through to the fenderwell... I got an EBAY kit and put a K&N filter on it... my ebay kit came with all the clamps, boots, and hoses, and even a rubber piece to line the hole with to cover the sharp edges all for less than 40 shipped (plus the filter, which i already had laying around)
                              here's a link to the kit i got...
                              Cold Air Kit
                              91 EX Coupe 5 Speed
                              My Ride Thread
                              ASE Certified Master Tech Since 2005
                              That's like watching a guy stick his head up his own ass. Impressive... but why?
                              Bought From: Quakerjoe , MikeW
