Old 12-09-2009, 03:05 PM   #1
Jam
Jam may have said something they shouldn't have...
Send a message via AIM to Jam
What would cause my windshield wipers to stop working?
92 accord dx. They just randomly stopped working. Not cool, were supposed to get a pretty gnarly storm in the next few days.
Any ideas? Thanks
94 Honda Accord EX - cozy daily
95 Civic DX w/ lamesauce b18
92 Honda Accord Discount Xtreme - 400k miles strong
04 Honda Helement EX AWD - GF's ride
Jam is offline   Reply With Quote
Old 12-09-2009, 03:42 PM   #2
Accrdwgnguy
Start with the fuse
"Discount Xtreme"?? Love it
Old 12-09-2009, 05:21 PM   #3
Jam
Originally Posted by Accrdwgnguy View Post
Start with the fuse
ya, power nothing, no painted bumpers. hell, I don't even have a pass side rearview mirror! I didn't even think that was legal.
either way, they still don't work. haven't checked the fuse but if that's not the issue any other suggestions? I seem to remember driving through a rather large puddle right before no workie....
also, they move rather freely when pulled. they both move at the same time still when pulled by hand. bad linkage from motor to wiper assbly?
Old 12-09-2009, 06:58 PM   #4
MethodFX
MethodFX is cool... so far.
happened to my boss' 93, turned out to be the plastic bushing on the motor broke and wouldn't move the arms. can you hear the motor working? if so, take your cowling apart and change the linkages.
MethodFX is offline   Reply With Quote
Old 12-10-2009, 12:26 AM   #5
Jam
yup, after taking a quick 2 minute look i can def hear the motor working at faster speeds when you turn it from int to low to high. fuse is still good too, obv. fuck
so what broke? anyone have a diy or a diagram of the wiper assembly? thanks
Old 12-11-2009, 02:18 AM   #6
Jam
no one had the part i needed in stock. honda dealer should have it tomorrow am
this has fucked up my day pretty badly. i had a pretty miserable day
Old 12-13-2009, 02:10 PM   #7
94blckhawaiian
94blckhawaiian is cool... so far.
driving around with one side rearview mirror would make me sad too. u should fix that asap
94blckhawaiian is offline   Reply With Quote
Old 12-15-2009, 10:13 AM   #8
Jam
dude, nothing needs to be "fixed" it didnt come with one. its a dx, it came with a block off plate.
anyone have a link to a write up? thanks
Old 12-15-2009, 12:20 PM   #9
CB7 Sleeper
The Solution
CB7 Sleeper seems to have made some friends!
You should have a rear view mirror regardless. The DX came with both mirrors.
Anyway, sounds to me like it could be the wiper transmission. Just a thought.
R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
CB7 Sleeper is offline   Reply With Quote
Old 12-15-2009, 12:46 PM   #10
Brandoncb7
Brandoncb7 seems to have made some friends!
Send a message via AIM to Brandoncb7
There are plastic bushings/caps that you HAVE to get from Honda. Although they don't sell just the plastic pieces. You have to buy the complete linkage if I remember right. I went to a junk yard and pulled one to fix mine. I think Honda wanted like 50 dollars or more for the part and I got it for around 10. It's really easy. Take your wipers off, 1 nut holds each of them on, then take off the plastic cowling that goes across the bottom of your windshield. Then there will be a couple of bolts holding the motor and linkage and everything in and you take them out. Swap in the other one and do the reverse and you should be good. Let me know if you need this explained better. I tried every parts place around here and ended going to the junk yard because of how expensive Honda was lol.
Brandoncb7 is offline   Reply With Quote
Old 12-16-2009, 12:16 AM   #11
Jam
ya, i bought them already. 2 metal rods with plastic caps on both ends. came to around $50 after tax. going to attempt this tomorrow
and cb7 sleeper, that is not true. i had an 88 civic dx that was the same way. block off plate for the pass side mirror, its legal
Old 12-16-2009, 06:50 AM   #12
CB7 Sleeper
The Solution
Well that, is odd. I guess I learn new things everyday.
Old 12-16-2009, 06:58 AM   #13
Brandoncb7
It's simple man. You'll spend more time taking everything apart to get to it than anything else and even that shouldn't take too long. Just make sure you watch how it's put together before you take it apart and make sure you do it the exact same way or your wipers won't move right. If you have a camera you may even want to take a picture. Mine got turned on to make sure the new motor worked and it took us a minute to get everything back to how it should be. Good luck.
