I recently ordered two feet of green flexible LED strips from Oznium.com
http://www.oznium.com/led-ribbon
here are the results!
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/IMG_5627.jpg)
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/IMG_5634.jpg)
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/IMG_5636.jpg)
I also installed new LED dome lights from Oznium as well... but I didn't take pictures of those yet.
Here's how it was done:
Using a fuse bus...
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/0826090855.jpg)
It comes with a pre-wired positive lead (the red wire) which I ran to a 10amp LED switch...
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/IMG_5646.jpg)
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/IMG_5647.jpg)
the LED ribbons came with some pre-wired junk that I had to cut out- they only got in the way.
the grounds from the lights run to the switch then to a bolt by the E-brake.
It took a while, only because I screwed up the wiring like a lot.
all-in all, it took about 50ish dollars to do.
the 50 includes the lights, fuse bus, switch and wiring couplers.
oh yeah, and there's this...
![](http://i44.photobucket.com/albums/f50/louddrummer4tsr/car/vtecyo.jpg)
shh... the only one that knows I don't actually have vtec is the guy next to me.
Using a fuse bus...
