5th Gen Trunk Space Upgrade
    My cousin said he likes the grey trunk of all 5th gens better than his beige trunk.
    His trunk needed some help...
    (left to right)
    So while I took a break from working on his F22A4, I sucked up all the water and dirt with a shop vac, sealed his tail lights to stop the leaks (I checked this with a garden hose), and then threw this in:
    (left to right)
    Now we both have beige interiors with grey trunks.
    1997 Honda Accord EX-V6:
    C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
    MPZA - Electronically controlled 4-speed automatic, 1 reverse
    ~170 cu. in. / ~170 ft. lbs. / ~170 whp
    Originally posted by James Matteu
    You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
    cool, did u paint it or jus got the parts from picknpull?
    Retro!
    Hater
      No Paint!
      I got all the parts from a Pick-n-Pull. I spent $58.
        Damn... Looks freakin' nice I need to do this with my trunk cause it looks like ass. The beige carpet isn't even fuckin' beige anymore its gotten so bad. I wish my entire interior was grey too though...
          What did you use to seal the tail lights. Cuz mine have just started to leak a lot.
            Dam 58 beans....
            Looks fresh tho
              looks good now
                I used something I had handy: Hondabond. I should have used bathtub caulk, that is what I used on my 1987 Honda CRX DX when it had a similar leak. I say I should have used the caulk because it is much cheaper than Hondabond.
