I want to buy a motor to do a rebuild or all motor on the side until my motor stop running
Is a all motor the same as a rebuild motor?
"all motor" is refering to that fact that the engine has no power adders, ie nitrous, forced induction. Rebuild is just that. It is a simply rebuilding a motor. A good rebuild consists of new bearings, seals, rings at a minimum. An all motor set up usuallly has a a rebuild but its not done with stock parts. I hope this helps.
Originally posted by moetan View Post"all motor" is refering to that fact that the engine has no power adders, ie nitrous, forced induction. Rebuild is just that. It is a simply rebuilding a motor. A good rebuild consists of new bearings, seals, rings at a minimum. An all motor set up usuallly has a a rebuild but its not done with stock parts. I hope this helps.
Originally posted by 09cb7 View Postso would a rebuild/all motor will make the motor stronger and lasting loner to run?
Originally posted by NinJa_FLiP View Posta full engine rebuild will generally bring the mileage back down to zero.. making it all motor wont.. LOL.. to make it simple, forced induction or FI as you might see it means either adding a turbo or supercharger (some add nitrous into the mix).. all motor refers to a motor that doesnt use FI.. if youre still lost, God help you man, coz we cant!
Originally posted by 09cb7 View Postlol i understand that but why wouldnt all motor bring down the mileage?
Originally posted by cb7emokid View Postim a all-motor build the point is to make the most power without using FI. You are not rebuilding the engine manly just replacing parts with higher output equipment. To rebuild the engine you would need to replace ALL gaskets, seals, i would even replace my senors. Honda had a problem with them for a long time. If you want to do a all-motor build. I say rebuild your motor while you do it.
Originally posted by 09cb7 View Postso you sayihg that its possible to do a rebuild while i am doing a all motor
when you rebuild a motor. you replace old stock parts. with new stock parts.
when you do an "all motor build" you replace your old stock parts with NEW FANCY PERFORMANCE parts. such as cams, valves, springs, pistons, rods, ect.
do you comprende?
no speaka engrish?
Originally posted by 92jdm View Postok keep reaching. you will grab something eventually.
do you comprende?
no speaka engrish?
