Slid and Hit the Curve = BIG DAMAGE
    My car slid and hit the curve going onto the highway
    From what i have look at
    I needed new caliper (caliper cylinder is bent), New knuckle assemble because it bent, new rotor and new pad , new wheel, and maybe new bearing.
    Could my axle bent since my knuckle bent inward? From what i saw my axle seem to be fine.
    Updated:
    2nd: Last post on page 1
    http://www.cb7tuner.com/vbb/showpost...9&postcount=20
    3rd Update:
    Took off lower control arm....very bent indeed
    http://www.cb7tuner.com/vbb/showpost...7&postcount=39
    4th Update:
    My uncle and I tackle the knuckle and axle
    here is the updated post
    http://www.cb7tuner.com/vbb/showpost...9&postcount=45
    damn thats some pretty damage how fast were you going??? something like this happened to my old cb before i got it and they snapped the rear cross beam.
      Pull the axel out and check for play. Check your balljoints and tie rods as well. From that impact , many components are in danger.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        i don't know how fast i was going probably 20-30
        http://www.google.com/maps?f=q&sourc...h&z=20&iwloc=A
        it the on ram going into Belt Parkway
        Parts Cost
        Wheel 150
        Knuckle Assemble 200
        Rotor 120
        Brake Pad 40
        Bearing and hub 200
        Caliper 110
        Total 820
        Return Core -50
        Total After Return 770
        at my self
        Time to look for Impreza RS 2.5 (Pre WRX) around $3k
          My buddy has one. Very fun and peppy little car.
            Go To The Yunk Yard Ull Spend No More That $200 Bucks With 30 Days Waranty
              You had to have been going faster than that...
              I smacked a curb multiple times in my cb and never did anything that bad. Sucks though.
              I'd be weary of inner tie rod, cross member front and rear.
              Click for my ride thread.
                140 for a bearing???? Where'd you get these prices, Honda? I paid $25 for a bearing.
                You better make sure nothing else is damaged, such as the control arm or even the crossmember.
                1992 Accord Wagon (RETIRED)
                  yeah the junk yard would be a good place to look first for some of the smaller parts why does 1 rotor cost 120???? i just bought almost my whole brake system minus the calipers for under 300 . and they were the best one i could buy too.
                    oop that was hub
                    i'm pretty sure i need both Hub and bearing 200 according to tasauto
                      ouch...go to the junk yard for parts...will be much cheaper.
                      -1993 Accord EX SOLD
                      -2012 GMC Canyon V8 4x4
                        because i'm guessing i have to replace other side too since i'm replacing one side
                        anyone Know any good Junkyard in NYC ?
                          no you wouldn't HAVE to replace both sides. could if you had the money sure. check ur upper control arm as well. its prabally ripped out of socket. how did practially the entire brake assembley on that side completely shatter and ur tire is still holdin pressure? i would have thought the tire/wheel should have takin most of the hit. and honestly from a hit like that i would just replace everything on that side including the axel. if it ain't broke yet is def gonna start clickin very soon.
                          the rebuild!
                          http://www.cb7tuner.com/vbb/showthre...50#post2073450
                            Make the J-yards your best friend You should be able to pick up at least 70% of your parts there.
                              I've taken that entrance many times, That small curb did that much damage? Did you run over all the pot holes on the entrance also? I know someone locally that may have the parts that you need.
