skunk 2 intake manifold *H22*
    i found this and i thought i would share, as it was a nice bit of info.
    here is his first post and the site.
    " http://www.honda-tech.com/showthread.php?t=1993840
    H22 Intake manifold TEST RESULTS !!!!!!!!!!!!!!!!!!!!!!!!
    there it is...
    changing the throttle body with the stock and euro r manifold didnt make a difference at all, neither were port matched to the throttle body.
    the stock moded manifold consisted of a 98 h22 intake manifold with just the butter-fly plate removed.
    i did not finish my cut up stock manifold in time to test...
    the skunk didnt make any more power than euro r with out changing the throttle body. changing the tb made a little more from idle to redline as you can see..
    post any questions ill be happy to answer them. but i think the dyno graphs are self explanatory.
    the setup is as follows..
    stock 98 usdm long block
    custom header, 1/2 greddy 4-2, custom 2inch secondarys.
    3inch CAI
    balance shafter belt removed
    tuned with aem ems"
    hope this helped someone with their choice .
    "Self Renewed"
    good find ... i'm been looking for euro r with 70mm tb (like bdl). i hear this is one of the best combos ..but, u gotta buy the tb adapter plate. or maybe even a eldebrock 75mm...
    FS: DSM turbo parts,OEM parts, and more.....
    My Members Ride Thread - R.i.P
      you plan on running a shitload of boost? i think the 70mm with a fairly well built n/a setup is more then enough
      You have to think outside the box to get IN the box!
