EGR block off, what do you do about the wires?
    Ok you block off the EGR valve on the intake manifold, what do you do about the wiring harness that plugs into the EGR valve? Nothing?
    CUT THEM for a cleaner look
    Just do what PR CB7 said.
      i hate the word "cut" is there a better way to do it
      UNDERGROUND SOCIETY
      NEW COUPE MEMBERS RIDE THREAD COMMING SOON
        wont this cause a CEL?
          not if you block it off, an install the egr back on top of it
          UNDERGROUND SOCIETY
            That's what I was thinking... there has got to be a better way.
              what about those of us who live in emissions counties? does it make that big of a difference?
                what About Those Of Us Who Live In Emissions Counties? Does It Make That Big Of A Difference?
                Move To A Non Emissions State
                  you going to be running any engine management?
                  If not, then just but a block off plate and the egr back on top
                  Formerly 91AccordExR33
                  11.68 @ 127mph
                  417whp/375wtq
                  Sold: 8/2016
                    what are the gains from this ???? if any
                    UNDERGROUND SOCIETY
                      , lmao.. thats the easiest solution.. but emissions wise.. is this something that would cause you to fail? and what are the advantages of doing this?
                        Ok I guess I'll just block it off and leave the valve plugged in. I was hoping I could remove the ugly thing and replace it with a much prettier block off plate, but whatever. Last thing I want is a CEL.
                          I just want to keep my EGR system clean, blocking it off will do just that.
                            i never knew that.......why would blocking it off keep it clean ???
                            UNDERGROUND SOCIETY
                              We all know what the EGR system does right? Sends some of the exhaust back into the intake to be reburned, which is supposed to help with emissions.
                              There for you block it off, no exhaust gases get recirculated, no carbon buildup.
