okay so tonight i got my h started and running but the second i give it gas it stalls. the idle is fine. but i tap the gas it dies. the timing might still be a lil off but still. also it throws a engine code and only revs up to 6500 then pins. anyone got any ideas on what it could maybe be.
car wont stay running
Red Wagon DD - 1993 EX
http://www.cb7tuner.com/vbb/showthread.php?t=172734
Gray Wagon Project - 1992 LX
http://www.cb7tuner.com/vbb/showthread.php?t=166337Tags: None
anyone im stumped spent today messing withit
Originally posted by carcollectorkid View Postokay so tonight i got my h started and running but the second i give it gas it stalls. the idle is fine. but i tap the gas it dies. the timing might still be a lil off but still. also it throws a engine code and only revs up to 6500 then pins. anyone got any ideas on what it could maybe be.
i dont know what code i cant find any with the right code reader. i can give it gas but when i take my foot off it dies. if i keep it one there it stops at 6500.
i need to find someone who has a code reader. the shops are the only places that have an import obd1 code reader and they want 120 bucks or so to do it.
ill check that today when i go to my garage.
Originally posted by vh22accord View PostCheck the fuel line running to your fuel rail. If you did not tighten the bolt on the fuel rail it could be sucking air in the line as the engine revs down and loosing pressure as it reaches 6500rpm.
yeah i just checked it all everything is good and tight.
Here is my obd1 scan tool. I just mounted it to the diagnostic port on the passenger side kick panel and when I need to pull the codes I just flip the switch. works great. it was like $3 to make
IT IS WHAT IT IS
Originally posted by bigpoppa694lyfe View Postuse the paperclip trick 2 check ur cord. if u pull the kicker panel off the passanger side there should b a blue connecter. shove a paper clip in there and watch ur engine light
