OK, bear with me here, it's going to be a long story.
My 93 Accord LX began to sputter below 2500rpm but was fine above that RPM. It stalled out once or twice, but would start back up after a few minutes of cranking.
Took her home, pulled the plugs, and they were covered in oil. Found out this was due to the spark plug seals. So I changed the upper plug seals and valve cover gasket. Also, due to an oil leak and a missing lower screw on the distributor cap cover, the rotor button was covered in oil/grease and the contact points were all corroded. So I replaced the dist. cover and rotor.
Fired it up, and it still sputtered below 2500rpm.
I had a bottle of Seafoam handy, so I figured it couldn't hurt to try some. So I sucked a 1/2 can into the PCV vacuum port and produced a good smoke signal. Fired it back up, and it seemed to run about 75% better. So I dumped the rest of the can into the fuel tank and drove around a bit. After a while it went back to the same old problem. So I parked it for a while and drove my truck. I figured maybe the EGR ports were clogged and causing the stuttering since the car has 308k miles on it.
Skip ahead one week to today. I decided to go to the gas station and fill up the tank. Car started right up, and was running normal. After a few minutes the problems re-appeared and it stalled out on me. After a minute or 2 of cranking, it fired back up. Drove it home, and on the way there, while coasting downhill at about 35mph, the RPM's DROPPED to zero, while the engine was still running and I was coasting in 3rd gear. I gave it gas but the engine did not respond, nor did the tach come back to life. As I got to the bottom of the hill and began to go uphill, the car died. I sat there and cranked and cranked and cranked for several minutes, until finally the battery nearly died. The motor sort of stumbles while I'm cranking it, as if it's trying to fire up, but is not getting a good spark.
What the heck is the problem? I don't think it's the EGR anymore. That wouldn't cause it to not start and all of the sudden drop the RPM's to zero while I'm still driving!
I have no idea where to start. Could it be something electrical? Distributor? What? Please help, gas for my truck is killing me.
