air/fuel ratio guage
    i got one today and it said to hook up red to 12 volt black to ground and the purple to o2 sensor but what i wanna know is where can i f ind this at???
    sry for the big pic
    Backyard Customs
    Originally posted by xprojectcb7x
    why would you think people at auto zone would know what they were talking about?
    Building Fund: $0
    http://www.cb7tuner.com/vbb/showthre...="0" alt="" /> CLICK IT!!
    the o2 sensor? Its on your exhaust header if you have an lx or dx and right before the catylitic converter on the ex.
      but i need to know which wire cuz there are 3 comin from it..its called the signal wire i dont know what color it is
      Backyard Customs
      Building Fund: $0
        hmmm gonna need to go to a haynes manual for that one and i dont happen to have mine at my side.....amazingly.
          easy man i just got doing that to mine, red to 12v, black to ground and the purple one to the o2 sensor witch is the white wire ok man good luck.
          heres a pik of mine i got the same one
            dang that looks nice man
              would i have to run more wire to under the car or is there a wire under the hood i can connect it to
              Backyard Customs
              Building Fund: $0
                depends that wire not long enough? i ran mine through that lil vent and out the fire wall.
                Freedom Is Not Free
                U.S Army 02/08 Medically Discharged
                  you can even run to the ecu. i think its like d14 or something like that
                    okay i got a 5th gen pod but wit no hardware what can i use to hold in place..
                    Backyard Customs
                    Building Fund: $0
                      i ran mine to the ECU ... I am using a wide band too though ... my pod holds itself in place by pushing down between the dash and the pillar ... no screws or anything needed ... it is a universal pod
                        okay i was told to hook up the purple wire to the white wire on the o2 sensor but there is two white wires so which one, both are solid white
                        Backyard Customs
                        Building Fund: $0
                          well i picked one white wire and turned the car on it came on but says im lean ..where shouls it be at?????
                          Backyard Customs
                          Building Fund: $0
                            i believe you should be lean on idle. Take it for a run at WOT and see what it tells you.
                              Are you using a wideband O2 sensor? If not that AutoMeter gauge is only going to look pretty. Your not going to get a proper signal from a narrow band O2.
                              MR Thread
                              GhostAccord 2.4L Blog
                              by Chappy, on Flickr
