aftermarket or oe sunroof
    I'm apparently stuck with an LX cb7 but i'm lookin to swap a sunroof aftermarket or oe. is this possible and do you guys know where i can find these and how to install it? any help is appreciated thanks
    Once a CB7tuner always a CB7tuner
    I spose its possible, but cars equipped with factory sun roofs have additional support. If you just cut out a hole you're going to loose some roof rigidity and that probably be unsafe and unwise to do.
    ..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
    Sold to:tanNn2koo,9tAkord,ThrakBarts,nahmo,andrizzle,or anger
    Bought from:93a-lude, bruno8747, soysauce
    1993 H22A cb7 <3 miss you
    04 WRX stg 2 sedan
    Current - 02 WRX stg 2 wagon
      there are professional shops that will do the work but you would have to scout out the oem parts if you so decide to go with that -junkyard. or you can go with the aftermarket sunroofs that are manual pop-ups but im sure there are electronic sunroofs but those would cost you more.
      i wouldnt understand how the roof would be less rigid if you completely swap it over with oem parts. or how unsafe it would be?? cuz im thinking convertibles have no top, so how unsafe is that?
      my members ride page
        so i could just swap out the top roof with the EX one?
          drag-
          Hardtop cars and sunroof/convertible cars are built completely different, conv. cars have a rigid frame and alot of supports designed into them, same with sunroofs and t-top cars. You could do it but I would suggest looking for an EX that already has one. You just asking for leaks and other problems swapping one in. Sorry to rain on your parade I just wanted to give some advice, remember its your car and you decide how to build it.
            besides all the stuff mentioned at the top, cars with factory sunroofs have a little lip that goes all the way around made when they stamped out the roof. it would be possible to recreate it, but you would have to be a really good metal fabricator. and as for aftermarket sunroofs, i've never seen one that looked half decent or didn't leak.
            "I remember u and I, parked on lovers lane, Drinking each others blood, so young and insane"
              The EX (what I drive) has a frame support running the width of the roof of the car before and after the sunroof.
              FYI: The 'sunroofs' that pop-up but don't slide in or out of the way are called 'moon-roofs', since they don't have direct access to the outdoors like a 'sunroof' does. 'Moon-roofs' are fairly inexpensive, the installation cost is what brings the cost above $150-200.
              An aftermarket 'sunroof' will cost you a good $200-300 + installation, if you want one that doesn't leak and offers OEM-like interfacing.
              -mak
              Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
              Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
              Traded With: cb95spd, chessboxer, sohc em
              [ Completed | Pending ]
                thanks guys for the advice.. i'd take that advice. i'll probably purchase an EX over the summer and swap all my mods from my LX onto there.
                  That made me laugh for some reason.
                    Thanks for advice, I had the same question myself!
                    My 2004 Subaru Impreza WRX Thread
                      -mak
                      Is there any way to make a "sunroof" flip out as a "moonroof"? Any DIYs?
                      1990 Accord EX
                        I think you would need to swap the 6th gen accord's sunroof if you want the tilt feature, but the flipping out..... like the acura integra's? like how it goes over the top when it opens?
                          Yeah, like the 92-96 prelude and 92-95 civic!
                          1990 Accord EX
