I finally got my JDM bumper with the OEM intersection lights and harness well I was wondering where these 2 plugs went. I don't want to connect them to themselves cuz 1 of the wires is connected to both plugs with nothing in the middle so the to plugs are already connected by that wire but i dunno where they are supposed to go. anyway here is a quick pic for reference
Intersectin Harness Help
Originally posted by slickI finally got my JDM bumper with the OEM intersection lights and harness well I was wondering where these 2 plugs went. I don't want to connect them to themselves cuz 1 of the wires is connected to both plugs with nothing in the middle so the to plugs are already connected by that wire but i dunno where they are supposed to go. anyway here is a quick pic for reference
Originally posted by nhia-cb7what? plugs already connect? than why you still need those?
Originally posted by slickyea relay is in the middle these are on the end
in another word, everything already plug?
you kind of ask me something like this but I thought you were talking about the plug....
well as I remember right..there is one plug only to the relay..
and one plug for each side light..
That leaving only one plug left...which is the power only..
But theres no plug to it...So I cut it and power to the bumper signal light..
plus a back fuse to the fuse box...
thats all I did..Hope it help..
The pic i posted is at the end of the harness on one of the sides after the plug for the intersection light itself. The relay is in the middle and there are places to plug the stock corner lights in on both sides. All of this is hooked up except these two plugs.
I guess im going to have to take my bumper off and figure out where they go. I still don't have them on i was just making sure i knew where they went firstMaple50175 - you're annoying =P
hmmm....maybe because you had the JDM bumper?
I don't remember I had that..just one plug to each light right before to the blub..
and one to the relay..plus an extra one where I don't know where to go..
ask MR.PHIL. hes got them
93 Accord LX Sedan (sold)
Originally posted by tn_accordsok .. on the plug with two wires.. the one solid color wire should be your constant hot wire and the other should be a ground wire. on the other plug with one wire is your ignition hot wire.
well at least that is how mine is wired up. it works just fine. hope this helps.
that helps now i need to know where to hook them up atMaple50175 - you're annoying =P
