A very easy tune-up you can do to ur car.
PCV= The Positive Crankcase Ventilation (PCV) valve prevents the release of gas fumes and blow by vapors from the engines crankcase. If it becomes blocked or clogged, it can cause oil leaks and promote the formation of sludge in the engine.
1. Find the pcv valve. it is in the middle of the valve cover. the tube that going from valve cover to intake manifold.
2. Pull the tube off and pull it from the valve cover(use pliers) and shake it to see if it rattles.
3. If it does then it's good, but i'd replace it anyways cuz it's cheap. If it sounds solid then its bad.Some times the inside is broken so u'll never know.
3. buy a pcv valve from ur auto store ( $ 3-5 )
4.Reinstall just like how u pull it off. ( make sure it goes all the way in )
After do this i feel that the engine is smooth and a bit of hp has come back.
ENJOY!
ENJOY!
