Ever since i did my swap from an F22a1 to an F20a my idle hasnt been right and when i turn on my ac on my idle dies down to about 400rpm and the motor is very shakey and feels like it wants to die...i raised my idle adjustment to compensate but then obviously with the ac off the idle is very high around 1500 or so...IAC motor is working so any thoughts?
Idle problem with ac on
you never want to adjust the throttle cable unless its really loose. First clean your iacv, fitv, and TB. If the iacv isn't working right then the idle won't raise for the ac.
The ac lowers the idle when it turns on because it draws power from the engine. The iacv accomodates for the draw.
Any Engine Codes?1991 Honda Accord 2DR LX 180,000 Miles RIP
well i did a simple test to see if my IAC is working i unplugged it while the engine was running and it bogged down so i plugged it back in and went back up so therefore i believe it works..and throttle body is completely clean no dirty...i havent checked my EGR to see maybe if its partially clogged but idk if that would have anything to do with it but as far as engine codes..i have a code for the throttle position sensor so i replaced it and measured the signal voltage when i installed it and set it to about a half a volt at idle but the code remains...would this have anything to do with the fact that im running a swap with the OEM harness and ECU? and yes it draws an excessive amount of power from the engine like literally a crippling amount i have to rev it up good to leave a light cuz the motor feels like its running at half the power
So you never swapped over harnesses and ecu, and you have a tps code. I would guess thats the issue. I am still running a f22 so I don't know much about swaps, but I would believe thats the issue.
What is your base idle set to. it should be around 550 the iacv is meant to raise the idle anywhere from 100-300 rpms.
My base idle is set to 600 and my idle is around 750-800.
Just one other thing is to check for air in the cooling system. Also have you cleaned the fitv (Fast Idle Thermal Valve) and the air boost.1991 Honda Accord 2DR LX 180,000 Miles RIP
