Thread Tools Rating: Thread Rating: 50 votes, 4.70 average. Display Modes
Old 08-18-2010, 08:46 PM   #61
Raf99
thanks everyone. Also have a DC sports header on the way. (2 piece, ceramic coating).
Time for some more goodies...
Old 08-22-2010, 07:02 PM   #62
Raf99
tried the pedals, but they're just not functional. took those off!
For getting those screws in below the ashtray.
(Thanks TypeG)
Old 08-29-2010, 09:08 PM   #63
Raf99
Skunk2 intake manifold install...
So I started this install today and I'm still not done. I started at 9am and I just got home now at 10:30pm. It took a while to label and remove the intake plenum and old intake manifold. Finding a new location for the black box that was bolted to the bottom of the old manifold was a challange too. I'm also not sure what this black box is . There is also one vacuum line that connects to this unit which use to connect to the IAB unit (to control the butterflies). I wasn't sure where to connect this, so I stuck it on a air nipple. I'm assuming I could close this line off and the computer will think the its "closed" off.
The other odd end that was left over was that the plate which goes on the IAC valves has air lines coming off. I assumed that you just loop the line to give the illusion (to the ECU) that an air temperature is being transfered.
I did start it but I only have 2 or 3 injectors working and I need more coolant. Tomorrow I'll bleed the coolant, add more, and check the injectors. I'll post some pics tomorrow hopefully too (forgot my camera).
Old 08-30-2010, 10:06 PM   #64
Raf99
I need to change the IABV vacuum line connection. There wasn't a spot on the manifold for this connection as it use to connect to the butterfly valve. I'm going to close that off to make the ECU think its closed. I'm thinking this is the same as deleting the unit also too, but maybe without a ECU code thrown. The FITV has to stay and the IACV has to stay as I do live up north and I will have a load on the engine. I'd like to eliminate the whole IAB unit if I could.
Old 09-10-2010, 08:33 PM   #65
Raf99
Old 09-10-2010, 08:49 PM   #66
stretch JDM
stretch JDM seems to have made some friends! stretch JDM seems to have made some friends!
nice ride man . great pics.
stretch JDM is offline   Reply With Quote
Old 09-26-2010, 04:51 PM   #67
Raf99
Well today the car was taken to have a new engine and turbo fitted and all the other goodies that go with that. It was a lot of prep work. The current H22A will be removed and fitted with the sleeved H22A block and new hardware. I switched the tires to the old tires and removed the stereo. We also got the car on the trailer and strapped it down. There were no issues with the trip up. I did bend in a rear lower quarter as I forgot to take a block out and the car bounced up onto the block and dented some metal. It can be fixed of course. Hopefully when the car returns I'll be the proud new owner of a GT35r turbo, sleeved H22A, piped and 3" outlet. There are a ton of other items on the list but I'll spare the details. Hopefully I'll have some pictures to share soon ...
Old 09-26-2010, 04:59 PM   #68
Darkcloud
Darkcloud is cool... so far.
Originally Posted by Raf99 View Post
Well today the car was taken to have a new engine and turbo fitted and all the other goodies that go with that. It was a lot of prep work. The current H22A will be removed and fitted with the sleeved H22A block and new hardware. I switched the tires to the old tires and removed the stereo. We also got the car on the trailer and strapped it down. There were no issues with the trip up. I did bend in a rear lower quarter as I forgot to take a block out and the car bounced up onto the block and dented some metal. It can be fixed of course. Hopefully when the car returns I'll be the proud new owner of a GT35 A turbo, sleeved H22A, piped and 3" outlet. There are a ton of other items on the list but I'll spare the details. Hopefully I'll have some pictures to share soon ...
Awesome can't wait to see that
How were those amps you got? Did they make a big or slight diff
Darkcloud is offline   Reply With Quote
Old 09-26-2010, 06:01 PM   #69
Raf99
To be honest i never had a chance to test them. I had everything I needed for the new stereo install and was all set to install it; amps, new 6x9, new 5"1/4, new 6 1/2" w/ pods, new tweaters, new in-dash dvd. I had gotten all the wires and connectors and was only missing the sound-proofing. Then the call came in for the engine and the car had to go to the shop. But I do thank ya for them
For others interested the list of engine parts were:
New engine parts
Darton H22A Sleeves
Arris 8.5:1 87mm forged pistons
Eagle H Beam Rods
GTR35 Turbo
38mm wastegate
750cc-780cc fuel injectors (need)
ARP headsteads
ARP rod bolts
ACL main/rod bearings
Aluminum Radiator (may not need)
31x12x3 Intercooler (recommend another size?)
ECU P28
Turbo piping and fittings
Log manifold
Turbo Timer (apexi, etc)
AEM High Volume Fuel Raid (needed?)
AEM Fuel Pressure Regulator
Fuel Pressure Guage
High Flow 255plh fuel pump
JDM/Gredy Timing Belt (hold)
Old 09-26-2010, 06:56 PM   #70
choogee3
choogee3 is cool... so far.
Where are you getting the work done?
Bought From : SE_DynamiK, oneoffaccord, and TopCop182
Click It!>>>><<<<Click It!
choogee3 is offline   Reply With Quote
Old 09-27-2010, 05:55 PM   #71
Raf99
Ravens Autosports are kind enough to help me out on this project. I had a chat with him today and its looking like the engine will be completed but we may wait until the sprint to put the turbo on as tuning in November isn't fun. Plus the car gets put away in the winter too.
Old 09-27-2010, 06:11 PM   #72
Clean_4th gen
Clean_4th gen is cool... so far.
Looking good brother. I like the progress.
1990 Accord EX
Clean_4th gen is offline   Reply With Quote
Old 09-27-2010, 06:30 PM   #73
Raf99
Thanks man! Right now it feels like backwards progress. Kind of frustrating. I got chips in the hood and a wheelwell to fix (from the move), and now with the turbo not going in until next spring....... ug. Kind of a set-back
Old 11-15-2010, 07:39 PM   #74
Raf99
My speaker pod mods i did...
Old 11-15-2010, 08:00 PM   #75
CBAccordA4
CBAccordA4 is cool... so far.
Im Confused.... Why did you get the DC Sport headers for h22 NA if you ordered all that Turbo shit. Also hiw did the gaains feel on with the Skunk 2 intake manifold if any. By the way, love the clean swap and plans you got, keep it clean, chill.
FOR SALE on cb7tuner only for now. Want it in the right hands
Pm meX
I do swaps in NYC/LI area: Hit me up for a quote.
MY WHIP
H22A Swap
I'm 'THE STIG'
CBAccordA4 is offline   Reply With Quote
Old 11-17-2010, 03:55 AM   #76
Raf99
You are correct, need a DC Sports header :P ? (the header was bought a while ago before I made the final decision on the turbo). The power increase was minimal for the skunk2 intake, but most felt in mid range rpm level.
Old 12-12-2010, 10:49 AM   #77
Raf99
Slow and steady wins the race in this case. But I got some pics of the latest progress. The engine bay turned out better than I thought, so I was excited to see it! I also got some pics of some new parts, super excited for this! I'll post some pics later; gotta run for a bit.
Old 12-12-2010, 05:04 PM   #78
Raf99
It was a good day today
Old 12-14-2010, 09:08 PM   #79
stretch JDM
^^ indeed it must have been a good day bro.looks as if santa came early your way pimp.nice parts man.keep it coming man.
Old 12-15-2010, 03:57 PM   #80
Raf99
thanx man. I still can't believe i got the engine bay done. Years ago I would look at the gunk on the firewall and the rust in the corners and wonder how I would ever find the time and money to not only take the engine out but make it look pretty in the bay. I'm super happy that its looking nice and shiny green!
