90 lx "S" light flashing when driving?
    I recently purchased a 90 lx sedan for 480$ the only thing i see wrong with it its that the sport shift light is blinking non stop when i drive. any advice would be appreciated.
    The TCU is throwing a code. Jumper the diagnostic port on the far side of the glovebox and the S light will blink out the error code, just like the check engine light would to throw its codes.
      o ok thank you ive never had an automatic before. thnx for your help
        i have the same problem but it started when i engine washed . the s light blinks but i don't get any difference in the shifting thank God. Everything works as normal I just want it off!
        the other thing is that no one can find the blue jack to dianose the ecu!!! not even the specialist..... Cause the engine light is on as well. It hunts when cold.....
          http://www.cb7tuner.com/vbb/showthread.php?t=21259
          Sold to: dbsharp, daheavyking X3
          Bought from:'93CB7Ex, xkjnboix, duffmanivxx, remix405, CB7tuner official shop
