h22 ig bogging
    h22 ig bogging
    h22 bogs between 3-4 thousand rpm thaught it was my egr but it isnt any ideals on what could be the problem
    have same problem and so do other people with h22.
      Is your CEL on? Does it come on when you reach highway speeds? Pull the code. I bet it's code 43, Fuel Supply System. Most likely, the oxygen sensor is the problem.
        yope my cel came on when i hit highway speeds.. ive change my o2 sensor and my egr valve , i dont know if the cel is still on because i have a mechanic working on it
          is the oxygen sensor the o2 sensor or it that something else
            Yes, they are the same thing. o2 is the chemical formula for oxygen, and used interchangably. (fell asleep in chemistry class, eh?)
              Wow, I'll jump on this bandwagon. I have an egr code, but I have no egr valve. But, I'm also running a p13, so, I know why my light is coming on.
                Yeah, not having the part that it's looking for will certainly give you an error code...
                  Doesn't seem to be running any different, other than maybe getting shitty gas mileage. But, I do a lot of in town driving, which isn't helping either.
