What a factory CRZ needs.
    http://www.mugen-power.com/automobil...nit/index.html
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
    cant process all that jdm-ness.
    COUPE K24
      TADA
      IMA hybrid CR-Z that has powered up and deployment of high-rotation type 1.5L i-VTEC engine, the adoption of lithium-ion battery that is 1.5 times the motor output. Aimed enjoy powerful acceleration from any speed range while taking advantage of the characteristics of this new power unit, if you step on the accelerator, the power unit deep-pocketed.
      It is necessary to consider the durability and achieve performance aim is not difficult . However , when it comes to compatibility with rugged enough margin , it is a challenge immediately . Infinite , select the centrifugal supercharger from a variety of development study article in order to clear this challenge . We chose the centrifugal is , the thing that I consider the running of linear to taking advantage of the characteristics and compact lightweight first , was to minimize the weight gain of the front overhang and mounting property to IMA unit . Further , since the speed increasing mechanism is provided , the rotational speed of the turbine and to about 18 times the engine rotation , and reaching approximately 120,000 rpm indeed the maximum output of 6,600 rpm. Increase the charging efficiency by the air cooled by the highly efficient intercooler employing a core has been designed for racing , is fed to the engine by the turbine rotating at a high speed by optimizing the combustion by the dedicated ECU, significant power-up becomes possible .
      In addition, according to the installation of supercharger, to optimize the air filter and air box. The engine on the bench, as a result of polished the torque curve on top of the thorough testing, to achieve 156 horsepower maximum output of up about 30% of normal ratio. While improving the working torque range performance of low-and medium-speed range, engine characteristics, achieve exhilarating engine feel up blow to penetrate up to high rpm. High performance unit with high rotary engine X supercharger XIMA weaves, the characteristics never before was born.
      It is supercharged by a supercharger to efficiently discharge the exhaust gas burnt . Power-up of the engine is completed by raising the exhaust performance . Exhaust tuning of MUGEN RZ is , reduce the exhaust pressure , such as by then straightening as well as up the tube diameter , to optimize the structure of the silencer . Same engine , specification is determined by the test bench over to again and again . It was also a shape to minimize the overhang to the body lower surface , airflow smoothly. Finisher realize the unique texture and lighter by a titanium . And is a exhaust note was stuck as well as performance . The realized sound quality by exhaust system is, of course, not the gear drive of the related art, by adopting a mechanism, called a traction drive system , compressor uncomfortable in an ultra -high speed range of about 120,000 rpm The supercharger eliminate mechanical noise . I was trying to enjoy the exhaust note purely
      Is one of the characteristics of the running of the CR-Z [3 mode drive system. So as to firmly draw the characteristics of each mode, over and over again piled up the engine test bench equipped with a supercharger, mapped to the dedicated ECU. In addition, it is a mapping with consideration to achieve a strong acceleration to maximize motor assist and engine output at the push of a button to [PLUS SPORT System.
        If I had the money to blow....
        '94 JDM H22A: 178whp 146wtq
          Hmm... my Fit has an L15A... too bad the Ecu is so specific...
          Though I would rather have a turbo charger...
            ooo i forgot about the crz..it captures the sexiness of a crx but with a futuristic twist..
            as much as a kamm back fan i am, I loath the insight.
              i love that this is available... i still like the idea of a modern day crx... a crz with a k is essentially just that. i will probably build one one day...
              "Tucking tires and wires."
              The Chronicles.
                Jackson Racing also makes a kit for it for 4Gs. Makes more power too. 190hp vs. ~155hp (115kW)
                http://jacksonracing.com/shop/superc...harger-system/
                member's ride thread
                91 Accord SE 176k
