Hey guys,
Looking for some help trouble shooting an issue that just popped up with my car. It is a 93 EX with an H22/M2B4, auto to manual swap. Ran perfect since we did the swap in 2011.
I havent been driving the car much and my battery drained itself to the point of not holding a charge. I had put a charger on it a few times and used the "engine start" mode and got it running, but it wouldnt hold a good charge. So I went out yesterday and bought a brand new battery. Installed it (relocated to trunk in 2011) and couldnt get the car to start. Radio, Dash lights, fuel pump, etc. all come on. 3rd turn of the key and I get nothing except a small pop through the speakers. No click from anywhere else.
I replaced both battery terminals and used dielectric grease. Cleaned my main battery ground and used the grease. Cleaned my tranny/chassis ground and used the grease. Cleaned my motor mount/valve cover ground and used the grease. Tapped the starter, no change. Battery fuse is good. Ignition fuse is good. ECU fuse is good. Starter signal fuse is good.
I did just drop my steering column to the floor and swap my dash and the car fired up before that. Wondering if I may have shook something loose.
I don't have a neutral safety switch since the car was auto. I will be checking the wiring around where the auto shifter was that I had to jump to get the car started when we did the swap.
Any ideas? Thanks in advance
