So I have noticed that I have a leak coming from around the ABS Modulator.
I first thought I was leaking PS Fluid from the speed sensor but, I drove around & did not see any change in the PS Fluid level. That was when I
noticed my ABS reservoir was a little low. I have filled the ABS up, so I will have to keep a close eye on the level.
I could not locate exactly where it was leaking from but there seems to be brake fluid
on the passenger side wheel well as if fluid is leaking from the left side of the modulator.
I cleaned up the dirt & gunk around the area so I can try to see where it is leaking from.
It does not look like it is leaking from the hard lines or the fittings though.
I am not too familiar with the ABS Modulator so, are there any well known
common leaking points that I can check?
Can I replace the whole Modulator from another CB or would that be a gamble?
I saw the DIY on the ABS delete but it I would like to fix the leak instead of ripping the whole ABS system out.
Any ideas would be great. Thanks.
