Help me identify this motor please
    So I got this motor awhile back for dirt cheap. I have tried to figure out what head especially this is. So from what I know it came out of a 93 prelude that they swapped an f20b into. I was told it's a "jdm" block and no one knew what the head is.
    USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_154128 3428169.jpg_1541283432373 by TwinStealth, on Flickr
    Accord by TwinStealth, on Flickr
    These are the only numbers I could really find on it.
    I am 80&#37; sure that is an f22b block DOHC NON VTEC with an USDM H23a1 Head on it. Which if they did that head swap correct may have had to modify either the head and block an oil passage or the block.
    ~Nick~
      It ran and drove before they pulled it. So Im guess they did the oil passages but I can almost guarantee the combustion chamber doesn't line up with the cylinder walls then. I have looked on here a ton and it seams like this is just a bad idea. Im just curious if its worth putting in since my F22a1 is leaking/smoking like a freight train, well after 4 grand and on start up (sometimes).
        its what it says. jdm f22b dohc. basically an h23 with iron sleeves. i had one in my coupe years ago. great engine.
        COUPE K24
          I was told the head isn't the original head for the motor and couldn't find what the head actually is. I have found a lot about p13 heads (which is an h22 head) but nothing really on a p14 head. I'm assuming it's an h23 but would just like to confirm before I try to mess with this motor or take a buddy up on an a6 head and rebuilding my f22a.
            P14 casting should be USDM H23A1. JDM F22B + JDM F20A DOHC are both PT2 castings.
