you should be good in no time.
keepinitclean : 1993 Accord SE
this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Thanks dude!
Sure hope it will
Look what came in the mail today
Special thanks to Nolan for giving me these works of art! I just have to do some trimming to have the projectors sit flush in the housing and after that I have to cut up the shrouds, I am still debating on them though
KEEP IT NICE, NOT RICE
So I put together one light really quickly and this is how it turned out:
As you can see it is shroud-less. I don't thing the gattling gun shrouds will do me any good. So Yay or Nay?
Stickers yaaaa! Oh, and I swapped back to the A6 plenum, I just need to let the glue dry before I start it up. Thanks DJM_coupe YOU DA MAN!
Originally posted by keepinitclean View PostThey are big enough. The sides of the projectors would also protrude a bit too. yea it does look kinda half assed.
Or just get some bigger shrouds.
I think those gatling shrouds would look awesome though. If you want, send me a PM with them mocked up and maybe i can get a better idea of what you're dealing with.
I didn't use any type of sealant...just made sure all surfaces were really clean and that the iacv rings were lubed a little bit. You can torque the bolts but its not necessary (just don't hulk them down)...sucks that it still didn't work though1991 Cappuccino Brown LX Coupe
2013 Rallye Red Civic EX Coupe
We need to hook up so I can install that plenum for you. I'm going to be on vacation the rally part of September do maybe wecan do it then. Are you going to try and make it to the meet on the 19th?2013 Honda Fit Sport Alabaster Silver Metallic GE8
2013 Accord Sport Modern Steel Metallic CR2
CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
