I ordered a full F20B swap including LSD trans, wire harness, ecu etc. My plans were to run the factory PCB ecu that came with the swap. So I got an OBD1-OBD2B ecu conversion harness, which I had to add 2 wires for the EGR. For the engine harness, I started with the harness of the F20B that went all the way to the ecu. I took the accord engine harness and followed each sensor back to the factory shock tower plugs for reference. An extra plug for additional wires like vtec and knock was added to the passenger side. I bought a new prelude distributor and converted it to internal coil and made it 2 plug OBD-1 style with the tach signal.
I did the timing belt job, with a manual tensioner conversion, new h22 timing belt and water pump. I also replaced the seals while I was there and put in a Skunk2 cam plug on the other side that was leaking. Compression is good on all cylinders.
Once the swap was installed, I had trouble starting it due to the reassembling the distributor 180 degrees out. Once that was fixed it fired right up. Then I lost spark, which ended up being my coil. Replaced the coil and it started back up. Noticed one of the header pipes was not warming up, which turned out to be a dead injector. Replaced the injector and now she is firing on all cylinders.
So that's the back story, now I need help.
The PCB ecu starts the car fine with no CEL beside initial priming. However, the header gets very hot very quickly. Within idling for a minute, the header is cherry red. It is turning the NGK plugs black. I ordered another PCB ecu to try and it does the exact same thing, again no CEL. The car also runs on a PT6 and a chipped P06 without the header heating up. Both throw a CEL 12 for CYP.
I've seen almost nobody actually use the PCB ecu, but I would love to have this engine running with ultra low emissions and a functional egr.
