egr delete
    egr delete
    I would like to delete my egr, and remove it from the car. The reason i want to do it b/c my egr system is bad on my car. The control valve went out. I have looked at the wiring schematics for this system. Looks like this can be done with relays and resistors. I just want to know if anybody on here has tackled this?
    thanks
    chase
    I looked through a few threads on the topic, and it seems most people just block it off. I haven't seen anything about wiring up something to fool the ECU into thinking there's a functioning EGR valve there. It'd probably be easier to just pick up a new control valve, or even a junkyard one.
      Yea i did a search and could not find anything. You are right it would be easier to just fix it, but i like challenges. I am going to see what I can do. If it works out i will let you know.
      chase
        Definitely. It'll be a good addition to our collection of cool stuff. Write up a DIY and you'll be immortalized in the DIY section!
        If I find anything, I'll post it up for you.
          I'd imagine you could redo a few wires and trick it... Just gotta rerun them to something in a similar circuit... I'm no wiring guy but thats the only thing I can think of
            When i get it done i will put it up in the DIY section. Bascally that is what it will be a small circuit. When the egr is commanded to be open i need x volts going to the computer input and when the egr is commanded to be close i need y volts. This will all be control by the out put on the computer. Hopefully i will have this completed in the next couple of weeks.
              Wouldn't it be easier to chip a p06 and then have it programmed not to look for the EGR?
                When you say chip a p06 are you referring i just burn my factory file on the p06 minus the egr function?
                  how much would that cost next to couple bucks in components and some grey matter time.
                    desolder the ROM and resolder in a new socket and EPROM and yes load a customized..firmware i guess you could say nullifying the EGR specifics
                      Yea you can find a po6 chip it and delete the egr
                      NEW CB
                      new
                      DARKCLOUD : 90 ACCORD EX MRT
                        would this work?
                        cut the plug off the egr.
                        wire it to a relay so whenever the egr needs to flip on it throws the relay switch?
                        maybe i dont understand how a relay works but i would imagine u could wire up some sorta switch to nothing just so it tricks the circuit to the comp that the egr is functioning and switches off when the egr is not needed.
                        thoughts on this.
                        Accord SE
                        93se
                        Members Ride
                        Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
                        Sold to: sulimed, BurtonRiderT6, tishock
                          I think what he is trying to do is wire in a relay to close a circuit when the solenoid would fire than take the optimum voltage from the sensor and recreate this using a resistor to send this back to the ecu to fool it into thinking the sensor is functioning properly, from what I just read it should be around 1.2 volts closed and 4.2 open from what I've read. Nice work on thinking outside the box, this mod would be cheaper than a chipped ecu.
                          My work in progress!
                            excatly what i was going to do. the computer will turn pull the relay in when the egr is supposed to open. when the relay is closed 1.2 volts will go to computer to tell it that the egr is closed. when the computer request the valve to open the relay will pulland 4.2 volts will go to the computer to tell the computee the egr valve is open.
                              but chipping a p06 has its other advantages as well...
                              I <3 G60.
